black_slug
Remove and replace tiptronic shift cable.
http://forums.tdiclub.com/showthread.php?t=507734
***UPDATE***
This thread I found makes me think it is the shift cable and not the solenoids or anything else, confirming my originalish suspicion.
https://forums.vwvortex.com/showthr...or-Moves-Transmission-Ignores#/topics/5840625
It basically describes my symptoms to a T.
Still wondering what ya'll think.
***UPDATE***
So here's the rundown...
-Car throws P0743 fault but generally seems to shift ok. I begin having issues getting directly into D as sometimes the selector display shows 4 when I'm clearly in D. My shift guide is pretty much toast so I order a new one. COVID slows it's delivery way down.
-Then I begin having a mechanical issue getting it into drive, need to
shift PAST D and then back up. This steadily gets worse as I wonder where my shift guide/enclosure is and I wonder what else it could be.
-Eventually the car fails to shift out of park altogether and I have a handy tow truck driver assist me in physically popping the gear lever from the engine bay, into R, D, then back to P so I can get it home safely.
-I finally install my new shifter enclosure but am not hopeful it will fix it at this point. It doesn't.
-At this point I had already begun to suspect the shift cable has failed. Then I start stumbling on the brake light switch issue and think my problems will be solved with a quick and easy fix.
-My brake lights work, the switch plunger moves freely and I hear what I imagine to be a healthy electronic click as it is engaged and disengaged with the depression of the brake pedal. It is also the newer green version.
-Could my problem still be the switch? I'll likely replace it anyway since it's so cheap in stock close by to 100% rule it out but I don't think that's it.
-Could it be this "interlock" cable 1J1713303? This is in the cabin running directly from the shift assy up under the dash.
-Lastly, I recently got the OBDeleven scan tool and picked up these faults:
00264 Solenoid valve 4
01045 tiptronic switch
Can I, should I clear these codes? I'm fairly confident the second one will clear now that the new guide is installed and the 00264 seems unrelated to my current symptoms but I don't know.
-What do you guys think?
***UPDATE***
***UPDATE***
