Old May 22nd, 2020, 12:53   #16
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Originally Posted by Blacktree View Post
Speaking of curveballs, I had to fix a sudden coolant leak. It took awhile to find it, because the faulty hose was hidden behind other stuff. The offending part was a short section of hose that connects between the cylinder head and a T-fitting, underneath the vacuum pump.
Oil leaking from the vacuum pump must have softened the rubber. I replaced the seal for the vacuum pump when I replaced the timing belt a few months ago. So this shouldn't be an issue anymore.
Had the exact same problem with my coolant hose.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
Old May 28th, 2020, 07:45   #17
Blacktree
Blacktree's Avatar
Fuel Economy: 44-45 mpg (mostly city)
The "wheel makeover" is complete! I'm very happy with the results. Here's a sneak peek:
I'll have a video up tomorrow.
Blacktree is offline   Reply With Quote
Old May 29th, 2020, 11:19   #18
Blacktree
Blacktree's Avatar
On these aftermarket wheels, the center caps are painted. But the rest of the wheel appears to be powdercoated. On the plus side, the powdercoat is holding up great. But the clearcoat on the center caps was peeling off. So I decided to refurbish the center caps. I also decided to add some VW badges for that "OEM Plus" look.
Here's a video of the work I put into it:
http://www.youtube.com/watch?v=9gZXiYvFPh4
And a shot of the finished product.
Old June 1st, 2020, 12:27   #19
Blacktree
Blacktree's Avatar
Here's an update on the Jetta.
I had to revisit the catch can install, to fix some minor issues. Plus, the missing battery cover was bugging me. So I modified it to fit. Also, the engine cover was rubbing on the breather hoses, so I clearanced it. Also, I decided to put some filter media (metal Brillo pad) in the catch can, to make it more effective.
Here's a quick video about it: https://www.youtube.com/watch?v=pNthOSkQmRs
Old June 26th, 2020, 11:18   #20
Blacktree
Blacktree's Avatar
It's been awhile since I posted anything Jetta related. That's because I've been chasing more cooling system issues. That split hose was just the beginning.
https://www.youtube.com/watch?v=wEer3b25d6A
Old June 26th, 2020, 11:22   #21
KrashDH
TDI(s): 2002 Golf
Interesting on the steel wool filter, that kind of makes sense. Is your catch can baffled and it was still getting through the baffled part? I may have to do this to mine as well
KrashDH is offline   Reply With Quote
Old June 26th, 2020, 18:42   #22
wonneber
How about stainless steel scouring pads packed in a bit tighter?
Old June 27th, 2020, 08:25   #23
Blacktree
Blacktree's Avatar
The catch can has a rudimentary baffle. But it's just a piece of perforated sheet metal. I think if it was made of screen or mesh, it would be more effective.
Also FYI those are stainless steel scouring pads. I wouldn't advise using steel wool.
Old July 3rd, 2020, 15:13   #24
Blacktree
Blacktree's Avatar
Recently, the Jetta has been making "coffee grinder" noises on start-up. I wasn't sure what was causing it. But someone on Facebook suggested gunk buildup inside the starter. So I decided to take the starter apart and see.
https://www.youtube.com/watch?v=eKQapdwFhPk
Long story short: lots of clutch dust, and the grease was breaking down. After cleaning out all the crud and applying fresh grease, the starter works like new.
MK4 Jetta making new sounds under the hood biglsells VW MKIV-A4 TDIs (VE and PD) 28 December 4th, 2017 14:08
06 jetta making noise under pressure deeman71 TDI 101 10 July 6th, 2016 13:16
mk4 Jetta making some noises bopsman TDI 101 2 February 26th, 2014 14:00
2001 Jetta Engine Making Metalic Noises tdi125 TDI 101 1 March 2nd, 2010 08:07
My 1998 Jetta TDI is making two sounds... itsmatt TDI 101 2 December 22nd, 2008 09:33
Page generated in 0.11113 seconds with 11 queries
[Output: 95.05 Kb. compressed to 81.74 Kb. by saving 13.30 Kb. (14.00%)]
