Old April 24th, 2020, 20:46   #1
fatmobile
Default My first TDI. A 2000 Jetta
I finally got a TDI of my own.
I've been working toward one for awhile.
Been putting the VNt 15s on my Rabbits for awhile.
Got an MTDI project running.
Worked on someone's ALH,.. timing belt and pump reseal.
This guy stops by yesterday and asks if I want to buy his Jetta.
The windshield is cracked bad.
The rear bushings need replaced.
The 5th gear is out,.. I think because the tower moves so much.
265,000 miles.
Needs a timing belt.
Inside is trashed.
Tail light broken.
Runs great.
$350 delivered to my yard.
A friend of mine has several parts TDIs
that he is trying to clear out so I'll be able to get the parts.
Dark dark purple?
fatmobile is offline   Reply With Quote
Old April 24th, 2020, 21:45   #2
GlowBugTDI
GlowBugTDI's Avatar
Fuel Economy: 43 mpg average
Congrats! sounds like a good project. Not a bad price if you don't mind a lil work.
GlowBugTDI is offline   Reply With Quote
Old April 25th, 2020, 04:30   #3
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
5th gear could be out because they let the trans run low of fluid. Just a warning.
For that price you really cannot go wrong.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is offline   Reply With Quote
Old April 25th, 2020, 19:08   #4
GlowBugTDI
GlowBugTDI's Avatar
No kidding. Round here (MN) the motor itself is worth at least $600+
Sent from my SAMSUNG-SM-G890A using Tapatalk
Old April 26th, 2020, 23:49   #5
fatmobile
I could part it out but will try to fix it.
I'm aware the missing 5th could be caused by low fluid.
I'll check that but the tower might be an easier fix and needs done for sure.
I'll need to research how that's done.
Can almost feel 5th If I push hard.
If that doesn't solve it, I'll pull the end off the trany.
The guy I got it from got it for $400 from a someone who was driving down the road and it quit.
Said the timing belt went.
It was just a clogged fuel filter.
He put 30,000 on it.
A few dents but the body is pretty rust free.
Old April 27th, 2020, 19:17   #6
wonneber
Are you saying the filter only had 30K miles on it or he drove it for 30K and the belt broke?
Fuel filter should go much longer w/o cloging.
If the belt broke there will be valve damage.
This requires head repair at a minimum.
Possible piston / rod damage.
Old April 27th, 2020, 21:28   #7
fatmobile
The guy he bought it from thought he broke the timing belt when it stopped on the highway.
Turns out it was just the fuel filter.
Shawn bought it for $400 and changed the filter,..
then drove it for 30,000 and sold it to me.
Old April 27th, 2020, 22:03   #8
STDOUBT
STDOUBT's Avatar
Dark dark purple?
Does that mean you're restoring, restoring her?
That's very cool man.
What would look awesome is deep purple based on the color family here:
https://www.automotivetouchup.com/to...en/2000/jetta/
Don't forget the metal fleck :-D
Best of luck on your restoration, and enjoy!
Volkswagen - turning owners into mechanics since 1938
STDOUBT is offline   Reply With Quote
Old April 28th, 2020, 22:55   #9
fatmobile
I'll have to check the paint code.
It's so dark it looks black at first.
Right, the plan is to fix any problems, drive it for awhile.
I have the rear bushings ordered.
Then sell it to a friend whos looking for a car with a stick.
I'm looking at a 2002 Jetta TDI wagon a friend has for sale.
Plan is to fix that up and keep it.
Old May 4th, 2020, 12:32   #10
fatmobile
Not sure where to find the paint code.
Here are some pics:
Trash car hehe
Side view,.. from the bad side:
Hey need your opinion.
This ABS speed sensor is OK right?
Just fine?
Supposed to be a backing plate protecting it right?
Where to get those?
I've traumatized you enough for today.
Starts/runs great.
Rabbits don't have alarms,.. that freaked me out.
Old May 4th, 2020, 12:44   #11
GlowBugTDI
GlowBugTDI's Avatar
Looks like my speed sensor...so ya for sure its good! Haha!
Old May 4th, 2020, 14:01   #12
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Paint code will be on the sticker in the trunk. Often these are disappeared.
Old May 4th, 2020, 19:42   #13
Caddy 16v
Caddy 16v's Avatar
That paint is "Atlantic blue pearl". LC5H.
Sent from my Pixel 2 using Tapatalk
2000 Jetta, mufflerectomy, Evolution Atlas skid plate, OEM xenon reps retrofitted, Hella Micro DE, HFLOX Warp 3 nozzles, 3 bar map, Malone Stage 5 Custom, Euro 17/22, DC Stage 4 clutch, STAGG suspension, Curt hitch, Auber EGT and NSP boost gauge, Hella Sharptones, Rally Armor mud flaps, 1.8T pancake pipe, upgraded SMIC, VAG-COM, all offroaded out
2000 Golf, JSP Armadillo skid plate, limo tint (Sold)
Caddy 16v is offline   Reply With Quote
Old May 4th, 2020, 20:09   #14
fatmobile
Thanks.
Same color as your 2000 jetta I'm guessing.
Bill said that's the only year with that color.
Old May 4th, 2020, 20:14   #15
Caddy 16v
Caddy 16v's Avatar
That's correct, there is also Indigo Blue but it looks way more blue and purple, as Atlantic blue almost looks black when it's not in the sun.
--Project-- 2002 Jetta TDI, 2000 Jetta TDI, both $1600. Mass 94x TDI Cars for Sale/Wanted 1 February 29th, 2016 05:02
2000 Jetta TDI and 2004 Jetta TDI - different suspension? sagging question mrrhtuner VW MKIV-A4 TDIs (VE and PD) 6 May 5th, 2013 08:44
2000 Jetta TDi Denver, CO, $2000 crzyjt TDI Cars for Sale/Wanted 19 October 28th, 2010 18:26
FS:2000 Jetta TDI (2000 CND obo) ONTARIO Le-coq TDI Cars for Sale/Wanted 2 March 4th, 2009 12:17
Page generated in 0.17486 seconds with 11 queries
[Output: 124.50 Kb. compressed to 103.65 Kb. by saving 20.85 Kb. (16.75%)]
