Old June 3rd, 2020, 13:26   #1
Pike25lb
TDI(s): 2.0
Default Camshaft replacement pd
Hi all I'm not sure if this is in the right section
I have a 2010 skoda scout 2.0tdi pd the cam shaft is worn so I am thinking of replacing it but I dont want to move the timeing side of things also dont have a vcd to fine tune the timeing so is there a way I can just do a straight cam swap and keep the timeing side fixed any vids or advice thanks
Pike25lb is offline   Reply With Quote
Old June 3rd, 2020, 18:11   #2
Nero Morg
Nero Morg's Avatar
Welcome to the TDI forums!
This isn't the correct section, however I can answer that you will likely have to loosen the timing belt to replace the camshaft. I am unfamiliar with your particular engine, but I've never seen a "don't loosen the timing belt" way of servicing a camshaft. Good luck!
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old June 3rd, 2020, 23:04   #3
Pike25lb
TDI(s): 2.0
Hi thanks what section shall I post in
Also thinking is the same as the jetter engine 1.9
Old June 3rd, 2020, 23:05   #4
Pike25lb
TDI(s): 2.0
Old June 4th, 2020, 01:20   #5
Pike25lb
TDI(s): 2.0
pumpe duse
Old June 4th, 2020, 03:01   #6
Tdijarhead
You will need to loosen the timing belt. You don’t have to remove it from the car however once loosened you’ll need to reset the timing. Many do the cam replacement and timing belt together because of this. Here is a write up.
https://www.myturbodiesel.com/thread...92/#post-16266
Camshaft caddy sdi pd or oem camshaft arl? Boyka TDI Power Enhancements 14 February 19th, 2017 11:37
Best replacement PD Camshaft? truck240 VW MKIV-A4 TDIs (VE and PD) 15 August 22nd, 2016 09:51
Best replacement PD Camshaft? truck240 VW MKIV-A4 TDIs (VE and PD) 0 October 11th, 2015 00:05
2004 Jetta PD camshaft replacement wvodiesel VW MKIV-A4 TDIs (VE and PD) 39 January 26th, 2011 21:32
Most miles on replacement PD camshaft hid3 VW MKV-A5 Golf/Jettas 10 May 9th, 2010 01:17
Page generated in 0.15740 seconds with 13 queries
[Output: 73.83 Kb. compressed to 64.83 Kb. by saving 9.00 Kb. (12.19%)]
