fuus
First I hope I've posted this in the right section, although my query is slightly non standard it is entirely about the PD engine
I have a Mk1 Caddy with a ASZ PD Engine, which I installed myself
It has been great driving round with the increased torque and power (a bit of a step up from the 54HP!)
However I have an issue: On start up the car seems to misfire? There is a lot of white smoke and it sounds to me like one cylinder is missing, but I'm afraid I don't really know all that much about these engines to say. After the engine warms up a bit the misfire goes away, which is why I've lived with it for a couple of thousand miles, but now I really want to sort it.
I hooked the car up to VAGCOM and got these readings out of the Measuring Blocks at cold start:
A few minutes later the values even out and the engine runs much more smoothly without the smoke:
Could this be some sort of lazy injector issue? Is one injector injecting too much or not at all do you guys think?
Ideally I'd not like to pay to have all the injectors rebuilt, but I guess I may have to go down that route if it comes to it.
Thanks in advance for any pointers,
Rufus
Rufus
