westerntexan
I have a 2003 A4 ALH engine TDI with about 130K miles on it. Usually got 44-47mpg until about 6 months ago. I had cleaned the intake manifold for the 2nd time around that time. The fuel mileage dropped to about 39mpg around that time. Of course I changed jobs and no longer do long highway drives. Nearly all city driving. I took a day trip recently and got about 45mpg on interstate. But I need to get a check engine light looked at (i blocked off the exhaust gas cooler and took care of the EGR valve). While I'm doing this at a trusted mechanic, I thought I'd get the injector nozzles replaced.
Maybe I don't need to get the nozzles replaced. I've read on here of people who insisted they really ought to be replaced at a little over 100K miles, others say they have the originals at over 200K. I did a search on nozzle upgrades.
Options:
1.The Kerma Powerplus 520 have +20HP and run $357. A fee of $357 to balance injectors. I'm going to subject myself to ridicule, but if something comes this highly recommended and is "so much better than stock" with closer tolerances in their manufacture, why would it need to be rechecked/rebalanced? Sounds more like having a vehicle scotchgarded when you buy one. I know, I'm old (way over 30) and I bought cases of ammo in the early 80s when it was feared that the russians would attack. Had to buy 'Mercun-made' ammo by remington but I've come to find that the chinese stuff makes jackrabbits explode just as good (had to use it for something, the russians didn't make it over. Not yet). There is a local shop here that will pop test your injectors for free.
2.Bosio Sprint 520 for $199 from TDI Parts (who I've used before). I think these have a +20HP upgrade, but correct me if I'm wrong.
What I'd REALLY like to know is, will the fuel economy stay the same or better, or do I have to worry that it might go down? The way I understand it, unless you really stand on it, it's not going to go down, but might actually improve.
thanks,
westerntexan
Options:
thanks,
westerntexan
