DieselCG
I'm trying to track down a fuel mileage drop on my 2004 PD Wagon 5spd. When I first bought the car, I would reliably get 42-44mpg with my mixed 70mile commute, with my average speed at 60-65 for almost the entire trip. Now, I'm lucky to get 38. I've gone through the drivetrain, replacing bearings and brakes F&R.
After installing my boost gauge, I noticed that I typically run a steady 7-8psi at 60-65mph on flat roads. Recently however, I've noticed that pressure sometimes "hangs" around 12psi, with no real clear cause. Sometimes letting off the Cruise or throttle and getting back on it will return it to 7-8, other times it goes right back to 12.
So, for those that have guages, what do you typically see at steady cruise? Any thoughts on the weird boost activity? I was thinking it may be the actuator or the vanes are starting to get sticky (car has just under 80k). One of these days I'll pull the turbo and clean it (bought it w/50k and haven't done it yet).
Thanks!
-Lloyd
Thanks!
-Lloyd
