AndyBees
- Joined
- May 27, 2003
- Location
- Southeast Kentucky
- TDI
- Silver 2003 Jetta TDI, Silver 2000 Jetta TDI (sold), '84 Vanagon with '02 ALH engine
I know there are aftermarket Cams available (Colt, etc.) for our TDIs. However, has anyone had an ALH or any other TDI cam, re-ground? If so, where, who and were you satisfied with the results (performance)?
I know with some cams there's not enough metal left to make much difference with a re-grind! So, it may be that these cams cannot be re-ground.
To be straight-up, I have no clue what the lift, duration, overlap, etc., might be on the ALH Cam. I guess that info is in the Bentley... just need to look.
Thoughts, comments...
