Its been like that for about a year now.
On idle, when clutch pedal is up, from time to time speedometer gets crazy and start bouncing in the range of 0 to 60 km/h. As soon as I press on the clutch pedal things settles down.
No significant noise change during this issue.
Cluster was changed and the issue has been happening on both cluster.
Speedsensor was changed last year.
Also, once in gear or on highway nothing to report.
It seems to happend on speedometer only. RPM needle is steady and looks accurate.
Any help would be appreciated.
Best regards.
Best regards.
