PD Rig
A friend has a "long distance diesel" that he keeps in his garage most of the time and also has an electric vehicle. He does a lot of short distance trips so he hardly drives his diesel, but when he does it is highway driving. He drives a common rail Passat. I was over at his place yesterday and he told me he changes his oil in his oil every 6 months. I told him that he was nuts and that he would be fine for at least a year between changes. Probably longer. I could understand changing that often if he drove it 5 miles and shut it off all the time. He said he is lucky if he gets 2000 miles between oil changes. At that rate I think he would be safe changing every two years provided the oil does not get too acidic in that time. Seems like a huge waste of oil and time to change it. Thoughts? Links to articles addressing this subject.? Since we are on the subject, could we address vw504/507 oil and cj4. I would assume a cj4 could sit longer In the sump than a 507 oil because the cj4 Tbn numbers are higher than The 507 from what I have seen.
