Selling my Silver 2002 VW Golf TDI, 5 spd., 4 dr. that has been tastefully modded (163 WHP). Runs perfect!! I'm the 2nd owner of this car and owned since 2008. I purchased the car with only 65K miles. It now has 116K miles. I had Andrew at AARodriguez Corp. (fixmyvw.com) do some modifications at 105K miles. The only reason I decided to mod it was because I was chasing the limp mode issue. I was tired of throwing parts at it and it not working. After I spent quite a bit of money with him doing the mods, it Still had the limp mode. After all that it finally turned out being my ECU. Andrew ordered a used ECU from a vehicle with only 46K miles, installed it, and have Not had a limp mode ever since. So, LOTS of new parts over the years I've owned it. The Timing belt, Surp. belt, water pump, pulleys, and tensioner were all done at 83K miles. Intake was also cleaned. The mods were recorded and we made a Youtube video of it. I will post the video and a list of parts / dates from my history with the car.
Mods include: VNT17 turbo, PP764 injectors, 3 bar map, SB Stg. 2 clutch, Malone Stg. 4 tune, EGR delete, and several other things. Records and receipts will be provided.
ASKING $7900.00 (Mods list and labor was almost $4K themselves).
Contact me: David at- Four Zero Four - 791 - Six 3 2 Zero
http://www.youtube.com/watch?v=iEaS0dI_gE0
2002 VW TDI LOG (THAT I KEEP IN MY CELL PHONE FOR MY RECORDS)
DATE -070708
FIRST change after purchase.
66,196 miles
Oil & Fuel filter change
Fuel Filter changed
ALL OTHER OIL / FILTER CHANGES DONE, BUT I FORGOT TO RECORDS DATE/MILEAGES. THEY WERE DONE BY A GOOD FRIEND WORKING AT A LOCAL VW DEALER AS A PROFESSIONAL MECHANIC
111909
New wiper blades
Shop Day-Nov. 14th 2010 - 83k Miles
New timing belt, surp belt, pulleys, tensioner, water pump, EGR deleted & Intake cleaned.
123010
Oil & Filter changed
91,464 Miles
020712- Brand New OEM rotors and pads. Front and Rear. 100,612 Miles. Used 5-Star wheels & tires installed.
Brand new AC Compressor and dryer , etc around 100k miles
P0674 - Cyl. 4 glow plug circuit
P0402 - EGR circuit flow excessive
P0245 - Turbo wastegate solenoid A low
P0118 - Coolant temp sensor ( been this way since I got it. Never caused an issue until until several thousand miles later & after timing belt / EGR service. Then started limping a while later.)
P1538 - Fuel cut off valve open circuit
010813
101500 Miles
New Battery!! (warranty replace)
May 2013
New parts installed:
New N75 Valve
New brake booster hose
New coolant temp sensor
New #4 Glow Plug
New 109 Relay (Under dash)
051213
102,203 Miles
New Glow plug Harness installed
050613
Oil & Filter change
102,613 miles
051513
Still code for #4 glow plug and throtle valve cut off.. Possibly ecu issue.. Codes cleared by Chris to drive and test again.
061513
New MAF Sensor
102,756 Miles
Limped on hwy. No CEL
061613 - 102765 Miles
New code popped up.
P3003 Low Heat Output Relay Short Circuit to B+ Static
Plus the usual Fuel cut off and glow plug codes.
But NO Wastegate code.
Cleared and went to see Orlando. He loaned me the two relays near the GP harness (53 & 100)
50-60 mile Hwy drive and NO Limp yet and NO CEL.
070113
Installled New VNT Actuator on Stock VNT15 Turbo
102,839 miles
020614
New Floor Mats
104,237 miles
040314
New Air Filter
104,350 Miles
062014
105,060 Miles
-New VNT 17 Garrett Turbo
-New South Bend Stg. 2 Endurance clutch
-New seals and rear main seal
-Bal. & Cal. PP764 Injectors
-Malone Stage 4 tune
-3 Bar MAP Sensor
-New Vacuum lines
-EGR race pipe kit
-Steel braided oil line
-New Fuel cut-off valve on pump
-Oil & filter changed
-Transmission oil changed
-New Glow plug in #4
070914
New Tires
Uniroyal Tiger Paws
195/65/15
105,773 Miles
071814
Used ECU installed w / 46,xxx miles
105,875 miles when installed
Testing for Limp Fix
Still "No Timing" shown on VAG
No timing again as of 072314 105,985 ish miles
No limp mode at all from 105,875 to 107,007 miles. (still not as of 101715)
080714
107,150 miles
Timing issue fixed by advancing the pump timing some.
New Glass headlight lenses installed
New dip stick tube
New wheel cap and logo
092514
New Dogbone w/ mount installed by AARodriguez
108,119 Miles
121114
Rotated new tires
109,685 Miles
030115
110,894 miles
New wiper blades front & rear
June 2015
Approx. 111k mikes
Oil & Filter Change
Feb. 2016
Approx. 113,400 miles
New Windshield
By Safelight
Jan. 2017
115,783 Miles
Oil & Filter Change
Fumoto Valve Install
July 15th
116K miles
Tires rotated
IMG]http://i929.photobucket.com/albums/ad137/BigSwole1255/TDI%20GOLF/C92662EC-96A8-4E92-8146-B68B259A0D76_zpsigeefpct.jpg[/IMG]
DATE -070708
66,196 miles
Fuel Filter changed
111909
New wiper blades
123010
91,464 Miles
010813
101500 Miles
May 2013
New N75 Valve
New #4 Glow Plug
051213
102,203 Miles
050613
Oil & Filter change
102,613 miles
051513
061513
New MAF Sensor
102,756 Miles
New code popped up.
070113
102,839 miles
020614
New Floor Mats
104,237 miles
040314
New Air Filter
104,350 Miles
062014
105,060 Miles
-3 Bar MAP Sensor
-New Vacuum lines
-EGR race pipe kit
070914
New Tires
Uniroyal Tiger Paws
195/65/15
105,773 Miles
071814
080714
107,150 miles
New dip stick tube
092514
108,119 Miles
121114
Rotated new tires
109,685 Miles
030115
110,894 miles
June 2015
Approx. 111k mikes
Oil & Filter Change
Feb. 2016
New Windshield
By Safelight
Jan. 2017
115,783 Miles
Oil & Filter Change
July 15th
116K miles
Tires rotated
