Well after venting everytime I fuel my NB for the last 73k miles, I decided there has to be an easier way.
I pushed on the vent tab towards the outside of the filler and it fell on the ground.
It is white plastic with two o-rings and the vent tab mounts inside. I removed the inside black tab assembly by prying it out and saved it in case some day I want to restore the vent lock out tab.
I removed the one torx screw for the filler door and rubber gasket assembly, the metal clip for the flap lock and the entire fuel door with rubber gasket came out. That exposed where to reinsert the white plastic piece.
Hind sight says remove the filler door and gasket first to see where the vent goes. Even better is to remove the right rear tail light and bingo everything is right there !!
I now have an open vent all the time when the filler cap is off for refueling.
No violation of EPA code, one just needs to remember there is no air pocket in the tank when full so the best time to do this is before you are going to put 50 miles or so on the vehicle.
