lowrider12
(from an ALH)
it's from an ALH
it's from an ALH
probably too long of a bolt was instslled in the rear main seal
Probably had the impact wrench set for "high torque"......and then they really reefed on it when it bottomed out!
Look for oil seeping from the affected bolt, as it now has a pathway to the outside.thanks for answers!
a TDI trusted mechanic replaced the head (with new AMC) about 10 months ago. The head gasket & timing belt needed service so we figured we might as well throw a new head on it while we're at it.
He did replace leaking main seal, and clutch.
Do the wear lines on the 2nd pic add any info? They're all in the same direction. Might those lines be original from the factory?
Many of us take our work very personally, I know I do (glad I don't work on cars).Sounds like you agree with the assessment of the "armchair" mechanics?
So why the attitude?
A simple "it wasn't me" would have sufficed. I expect you'd have made the same assumption if you weren't personally involved.
and where did he say it WASN'T from the rear main seal area? ... there are two machined areas inside the block that accept that size bolt on the opposite wall, one is the rear main, one is the front seal holder ... someone correct me if i'm wrong, but i'll confirm later on one of the disassembled "armchair" blocks i have in the shopMany of us take our work very personally, I know I do (glad I don't work on cars).
Some previous posts sort of concluded it was from the back side of the rear main, from a too long fasteners, he's just saying, No, it's Not.
Where's the middle finger emoji....and where did he say it WASN'T from the rear main seal area? ... there are two machined areas inside the block that accept that size bolt on the opposite wall, one is the rear main, one is the front seal holder ... someone correct me if i'm wrong, but i'll confirm later on one of the disassembled "armchair" blocks i have in the shop
possibly the front seal holder area then? it's uses sealer on the flange instead of a molded rubber gasket so it would not leak if broken throughThere are indeed two spots it could come from looking at the block I have here. Rear main seems the probable one. But if you use the correct bolts. The ones that come in the the stock rear main you won't have an issue unless there was a machining defect or assembly damage at the factory. I worked on the car 11 months ago. I can't tell you if I did a rear main or not. if it was the issue it would leak. Badly.
my thoughts as wellno arm chair here Jason, and nobody's pointing fingers at YOUR work obviously, but someone screwed up along the line somewhere
whatever dudeWhere's the middle finger emoji....
Chill out.
