For my first time replacing the clutch, steering rack, and pretty much my entire front end, things have been going good, but I hit a snag today. Didnt quite have the sway bar bushing clamp lined up right while bolting it up and realized I was stripping it out. Could not get the bolt to re-thread after that. I did my best using a tap (held by vice-grips) on the edge of the opening and with a new bolt I was able to get it going again, but it stops just short of bottoming out and just doesn't get any tighter. Should I have run the tap all the way through? I would need to pick up a proper handle. Could I try washers? Leave it alone without torquing down this side? How likely is it to back out here? It's pretty tight on there.
Thanks.
Thanks.
