Old August 12th, 2017, 21:06   #1
JettaTDlie
JettaTDlie's Avatar
TDI(s): '02 Golf
Default .216s with VNT17
I'm currently running a Malone stage 3 tune with SBC2 Daily, and Bosio 1019s (clutch/nozzles from previous owner) on my MK4 ALH. Just rolled over 300,000km and the original turbo is dying... takes a few shifts after start up to come off 0psi (with a mean whistle and little power), and consistently spikes to 25-30PSI at WOT.
I will be upgrading to a VNT17 shortly, along with a 3bar map sensor, which I believe will be the limit of my current clutch and injectors. I realize that .216s are relatively small but am wondering if they will limit my VNT17? I am not looking to change them, assuming they can optimize the VNT17, and I don't plan on getting into a VNT17/21 in the future. I was happy enough with my stage 3 tune... but why not upgrade if I'm already replacing! Any thoughts appreciated
2002 Golf TDI - Malone Stg 3 - SB2 Daily - Bosios - 3" Exhaust - Koni Coils - Aristos - Pioneer Screen - Poly Dogbone - HID Retrofit - Frostheater - Leather Swap
JettaTDlie is offline   Reply With Quote
Old August 12th, 2017, 21:45   #2
h4vok
h4vok's Avatar
The DLC1019 can flow quite a bit of fuel so it will be good. Are you going to get retuned? If not you should not need a new map and you will just need to adjust the actuator to run around 19psi wot.
DLC520, Mufflerectomy, Self tuned MPPSv16, more linked below
My car thread
h4vok is online now   Reply With Quote
Old August 12th, 2017, 22:08   #3
JettaTDlie
JettaTDlie's Avatar
TDI(s): '02 Golf
Was thinking I'd get a retune from Malone... not a huge price for an upgrade from stage 3 to 4 as a returning customer
Old August 14th, 2017, 14:16   #4
h4vok
h4vok's Avatar
If you are still on the stock intercooler check out fixmyvw they have a upgraded side mount then throw a 3bar map on for $200 total. You will want it with the extra boost pressure as you will heat soak the stock one like crazy. Personally I would say the DLC1019 are good for 90% of setups out there and I would not hesitate to run them with a vnt17 or 17/22. I think you will be very happy with the end result.
My car thread
Old August 16th, 2017, 01:41   #5
nikolay_ss
TDI(s): 1.9TDI ALH
I was running Bosio 1019 DLC on max voltage(4.46V) with GT1749VA at 1.4 bar and there was no smoke behind the car, car feels great and good response on throttle, those nozzles makes great injection, you can check my acceleration video at 5th gear https://www.youtube.com/watch?v=qcp5P9rGrrk
nikolay_ss is offline   Reply With Quote
Old August 16th, 2017, 12:01   #6
Owain@malonetuning
TDI(s): PD wagon
Yes these are great nozzles. I'd recommend running an 11mm pump if you want to really max out the turbo and squeeze the last 10-15hp out of it, but it'll support the turbo just fine. Larger pump will result in shorter durations, so less heat for the same power. We're running 1.6 bar on the VNT17s, or 1.5 on the 2.5 bar sensor (which I don't recommend since you won't be able to log boost-spikes comfortably).
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is online now   Reply With Quote
wtt 205s for 216s rollincoal97 Private TDI Items for Sale/Wanted 2 February 1st, 2011 18:46
Damn, thinking about .216s now... sportsguy Atlantic Canada 24 November 22nd, 2006 04:02
whos running 216s and what do they think? SENZEN TDI Power Enhancements 7 January 6th, 2006 21:35
Issues w/ .216s and Upsolute- Those who have it STRANGETDI TDI Power Enhancements 9 May 15th, 2004 10:31
FOR THE EXPERTS (.216s w/ a chip.) STRANGETDI TDI Power Enhancements 34 December 10th, 2002 00:29
Page generated in 0.12816 seconds with 12 queries
[Output: 78.15 Kb. compressed to 68.32 Kb. by saving 9.84 Kb. (12.59%)]
