I currently replacing my stock suspension, there is 207k on the car and the springs are so soft the car sits about 1 inch lower than they should also well I used to drive off road rally in my gas golf and the current situation will not work this winter as rally season starts in December. I have not decided to rally this car but would like to have the car ready just in case. I'm leaning towards http://www.srsvw.com/parts/suspensions/. This system does not lower the car, which is a concern for the off road and to combine it with a skid plate. Real Street Suspensions $995. I checked around I think you can put it together for $875 if you mix up the stores.
