TheBlackSabbath
My '02 Jetta TDI with 191k miles has, over the last 3 weeks or so, started leaking relatively small amounts of oil. Some days when I come out to check, there is no oil spot on the ground, but most days, there is one to three 2-3" oil spots on the ground. There is also oil all on the bottom of the front bumper, and all over the front passenger side of the engine bay, all over the piping, etc. When I stick my hand into the engine bay down there, it gets covered in oil. I may be losing a quart every couple weeks, probably not that much, kinda hard to tell since it's not been that long, but I haven't lost that much. It's not really bad and I've just been adding oil when it's gotten a little low, but its location (i.e., around what I believe is the intercooler piping) has me thinking maybe it's turbo-related (and I really have no turbo over the last few months, I figured it was prolly sticking vanes or an actuator, etc., but haven't had it checked out)
At first, it seemed like it was coming from the rear of the engine, and I took it in to a mechanic and they said it's a leaking rear main seal. This has me confused now, because the leaking now seems to be coming form the front. IDK how oil on the front bumper could have anything to do with the rear seal..... Maybe I have leaking from multiple sources that have just started at the same time? Not sure. I haven't really noticed more leaking from the rear.
Here are some pics. IDK a lot about TDI engines. What hoses are these? All the parts in the pics are covered in oil. The big pipe at the left of pic #1 & that's shown more closely in pic #2 has lots of oil around its base (all all over it) and seems to be loose when I try to move it, so I was thinking it might be something to do with that. Should I be too worried or it it probably nothing too serious? What should I do?
Any help is appreciated! Thank you!
