key won't open it, switch on fob won't and neither will the switch in the door. I can hear it trying but no luck. your ideas (especially based on past experience) most appreciated, thanks!
slightly irrelevant... but are there any tricks to loosen up the hydraulics on the trunk lift? When I bought this car, the trunk used to open on its own and now it's much stiffer...
