Newgene
I have developed a decent harmonic road vibration that I have really started to notice lately. It does only occurs when the car is moving, and it is directly proportional to the speed of the car. Is this a common result of worn rotors. I have tried to eliminate the problem by rotating my tires. I moved all the fronts to the back, and vice versa. I have also reduced my tire pressure from 40 psi to 30 psi, and nothing made a difference whatsoever.
I am assuming these are the original rotors on the car with nearly 140k miles. I wll change the rotors when I do the brakes again (getting close on the front set). The problem I have gets really noticable when I slow down, but it doesn't really seem to change with the brakes on or off, but it does increase as I slow down. That's the point when the engine goes quiet, and I just hear the road noise. When I hit 70 mph, it seems to be a constant humming vibration, and by then, it's hard to notice the harmonic nature.
Any thoughts on this? I'm guessing it's the rotors.
