CGR
My car is a 02 Golf 5 speed. The only engine mod is Sprint 520's. My original fuel pump is in the process of dying and I need to replace it soon. I managed to source an 11mm pump from a 01 with 43K on it so finding the pump is not an issue. It only seems logical that since I have to install a new pump I might as well upgrade. I realize that the pump/injector combo may kill the clutch an am prepared to upgrade if forced to. I don't like smoke so that is a concern of mine. Since some of the auto guys are running Sprints without smoke issues, is there any reason I would have problems dialing out the smoke on my manual transmission with the stock software?
I was considering chipping in September at RallyVW's tuning GTG with a RC Euro 1/2 switchable. I have driven the RC2 with Sprints and loved that combo but wanted the option of switching to stage 1 to save the clutch for a while. The RC2/Sprint combo was plenty of power for me and would have never went looking for more power but since I have to replace the pump is there any reason not to upgrade?
Anybody running RC 1 or 2 Euro with Sprint520's and an 11mm pump in a manual out there? If so, how is smoke and fuel economy? If I do the pump and the clutch holds, I will probably hold off on chipping until spring. I may also see about a stage 0 Euro conversion so I can install a racepipe and remove my EGR without getting the CEL and preserve the clutch until spring. Are there any arguments or reasons not to upgrade to the 11mm? Would I be better off just replacing my 10mm with another 10 mm?
If I do upgrade should I install the fuel cooler from the auto and is there any reason I would have trouble installing the cooler in the manual car? Are there any mounting brackets that are different on the auto that I would have to have in order to install the 11mm in my manual car? Thanks,
Greg
Greg
