Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5)
Audi SUVs (Q7 & Q5) Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US).
Old November 18th, 2017, 15:59   #61
Owain@malonetuning
Of course, we typically charge 100 for re-tuning and for any major accidents/vehicle replacements we address it on a case by case basis.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old February 13th, 2018, 01:19   #62
BarryT82
Have you tuned any of the emissions repaired Q5 TDI’s yet? The emissions repair is killing the fuel economy and I know some people wanting a tune.
BarryT82 is offline   Reply With Quote
Old February 13th, 2018, 10:03   #63
Owain@malonetuning
Yes we've been tuning a ton of them and started doing the 3Ls the week the update was out.
Old February 13th, 2018, 13:02   #64
AU_Bug
TDI(s): 2014 Q7 TDI
Fuel Economy: ????
Can the FlashZilla V3 be used on a 2014 3.0L Q7 TDI? It appears it can, but I can't tell on your site.
Also, if I buy the FlashZilla and Tune from one of your US dealers, how does the upload procedure work?
Does the FlashZilla come with the tune pre-installed?
If I need to take it back to for "service" can I put the "stock" tune back in place?
Is the "stock" tune stored the "updated" version from post-fix/recall?
I know it is a lot of questions, thanks for your time.
2014 Audi Q7 TDI Prestige
2009 Jetta SportWagon (TDi)
- 6 speed manual
- Panaromic glass roof
- Black Uni
AU_Bug is offline   Reply With Quote
Old February 13th, 2018, 14:07   #65
Owain@malonetuning
Yes it works and functions as advertised, so it does not come pre-loaded. The first thing you would need to do is read the stock file on the vehicle and then make up a file accordingly, so both are saved. Files are sent via email and loaded through the menu on the device.
Please email us directly if you have any questions since this isn't the place for sales.
Old February 13th, 2018, 14:08   #66
AU_Bug
TDI(s): 2014 Q7 TDI
Fuel Economy: ????
Thanks for the quick reply and information!
- 6 speed manual
- Black Uni
Old February 13th, 2018, 18:12   #67
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Maybe I can explain the procedure a bit better. Copying the OEM tune to the Flashzilla takes less than one minute.
1.) You plug the Flashzilla into your OBD II port
2.) Follow the instructions to download your original tune into the Flashzilla
3.) Disconnect the Flashzilla
4.) Take the Flashzilla and connect to your PC computer
5.) Make a folder and name it Malone tune.
6.) Save the file from the Flashzilla to this folder
7.) Email this file to Malone
Loading the new TUNE which comes by email
1.) Copy the new tune to the Flashzilla
2.) Plug Flashzilla into OBD II port and follow directions.
You should have a battery charger connected for this, it may take some time.
Everything except the ignition should be off for this procedure.
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Old February 13th, 2018, 18:36   #68
BarryT82
I can’t get the flashvilla to read the new stock tune on my Q5. It states that the calibration file isn’t found. Mine had the JR Auto Tuning file, but my wife’s has always been stock and she wants it tuned. They’re both the same year and model so I’m assuming that they have the same OEM file now.
Old February 14th, 2018, 08:47   #69
Jetta_Pilot
Originally Posted by BarryT82 View Post
I canít get the flashvilla to read the new stock tune on my Q5. It states that the calibration file isnít found. Mine had the JR Auto Tuning file, but my wifeís has always been stock and she wants it tuned. Theyíre both the same year and model so Iím assuming that they have the same OEM file now.
I'm not that knowledgeable about this, but my guess is that your Flashzilla has the "Tuned file" from your car in the system and won't let you read another OEM file.
Each ECU has its own identity, ie serial number.
Old February 14th, 2018, 09:18   #70
BarryT82
The flashzilla was erased so it could read the new file, but the new file isn’t in the database yet.
https://ibb.co/d7Xv0n
Old February 15th, 2018, 10:57   #71
viper550
viper550's Avatar
TDI(s): 14 JSW 6M
Fuel Economy: Winter 43-45mpg Summer 46-50mpg
Does the Malone tune help to get back some of the Lost fuel economy after getting the emissions fix done?
I'm wanting to get the wife a Q5 however getting the lost fuel economy back is extremely important.
Loving life with my 2014 Platinum Grey JSW 6MT w/no giant hole in the roof
Malone Stage 2
Rawtek turbo back w/ hi-flow cat and resonator
viper550 is offline   Reply With Quote
Old February 15th, 2018, 12:09   #72
Owain@malonetuning
Yes we alter the timing, feel free to shoot us an email and I'll send you some driving logs of before/after fix and how the tune affects that. I'll be making up an article at some point but have 20hrs of data logs to sift through.
The flashvilla was erased so it could read the new file, but the new file isn’t in the database yet.
This file was available as of Monday with Malone. Maybe not through your respective tuner yet as we're the ones building the database, the data is shared through alientech so other tuners benefit from our work and vice versa.
Old May 14th, 2018, 04:05   #73
mousaillon
TDI(s): jetta
good news i should get my flashzilla in a mater of days can wait to drive back my q5 with malone hope they put a sticker malone in the box
mousaillon is offline   Reply With Quote
Malone Stage 2 or CR170 stage 3 for 180k miles 2011 TDI JSW? calimustang VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 16 May 24th, 2015 13:17
Malone tuning stage 2 or stage 3 for ahu lbundy TDI Power Enhancements 4 June 23rd, 2014 09:44
WTT: TDI Malone stage 3 ecu for stage 1 ecu. FREE diesel69 Private TDI Items for Sale/Wanted 5 February 18th, 2014 15:06
2010 CR TDI 6 Speed Manual: APR Stage 1 or Malone Stage 1.5? hartzpad TDI Power Enhancements 5 November 25th, 2013 14:57
Page generated in 0.16113 seconds with 12 queries
[Output: 120.55 Kb. compressed to 101.50 Kb. by saving 19.05 Kb. (15.80%)]
