Finally Fixed!!!
Well everyone after months and months of troubleshooting (not wanting to throw parts at it to find the problem), the problem is finally fixed!!!! After the turbo adjustment, this car is one smooth running, non-black smoker, non-surging multiple owner TDI!! It is amazing that one little set screw can cause so many problems and relate to so many sensors including the, MAF, N75, ASV, EGR and many of the output tests on Vag Com, VCDS. After the adjustment I haven't seen one puff of Black Smoke and the turbo is very smooth, with smooth acceleration through all RPM ranges, and still produces specified boost as verified in VCDS logging. I would highly recommend adjusting the screw if you are experiencing any of the issues related in this thread.
Now as for the adjustment procedure that I used. I used multiple threads to finally come up with the correct adjustment procedure. Mainly
this thread, which explains how to adjust the set screw using VCDS. I also used the explanation in post number 62 above from Jeff "jsrmonster" and the previous post from Dan "DanG144". The procedure that I used is posted below, thanks to O.C.TDI.
For setting the stop screw... The setting on the bench is only an initial setting, it has to be adjusted on the running car.
This procedure works for the EDC16 cars, NA 2004-2006
Start with the car up to operating temperature.
Use VCDS, Basic Settings channel 011, turn "ON" The car will slowly idle up to 1400 rpm +/-. Now the VNT is in a calibration mode.
Note the boost values when the VNT is fully closed and fully open. You are looking to unjust the to have a 80 millibar difference between off and on.
Adjusting the screw out will increase the boost spread, turning the screw in will reduce boost.
Once you have tuned this check you actuator setting. I would start with the VNT at full stroke around 18" vacuum.
After this you will have to work with your tuner to fine tune the actuator to match up to the duty cycle and logs.
After each adjustment you should rerun the channel 011 Basic Setting so the smart actuator can learn the parameters of the VNT. THis will help the ECU adapt to the actuator faster than just driving around.
O.C.
I think that in order to adjust this correctly, VCDS, Vag-Com is a must. The set screw is extremely sensitive, to the point that it takes many small 1/8 turns to finally dial in the correct boost change between on and off. I think that I may have turned the set screw in about 1 to 3/4 of a turn for the total adjustment, and I was about 300 mbar differential between off/on N75 cycles in the beginning. After the first adjustment I could tell that I was headed in the right direction.
I don't want to repeat everything that has already been said, but I couldn't find a description of how to do the adjustment, and wanted to post what tools I used in order to adjust the screw. Also I have to give Jnitrofish credit for doing this same thing using zip ties in
this thread. After you start adjusting the screw and realize how small the increments are, you will wonder how it was possible to do the same thing with zip ties. Anyways, Below are some pictures of the tools that I used.
You have to access the screw from the bottom of the car. 1rst you have to take the skid plate off. Then look up from just behind the engine up towards the turbo and you will see the set screw. It is bumped up right against the oil line to the turbo, so you will have to use the 10 mm crows foot with a long extension or a few long ones like I did. The 10 mm wrench is for the lock nut, and I used a 3 mm hex socket to turn the stop screw. The tricky part is figuring out how to hold the lock nut while you turn the stop screw. So to do that I used a long flat tipped screwdriver to wedge between the turbo and the lock nut to keep it from turning while I adjusted the stop screw with the 3 mm hex socket on the long extensions. If you can, try to mark the lock nut and the set screw so that you can be precise on your adjustments. The main adjustment will be about 1 turn or less clockwise or tighter on the stop screw, depending on how far off your readings on VCDS are.
Here are some screen captures of the Basic Setting results after the adjustments.
A few problems that I encountered while adjusting it.
One: the set screw wants to turn with the lock nut, solved that by wedging the screwdriver to stop the set screw as explained above.
TWO: make sure that your A/C is turned off or you will get erratic readings and the end result will be wrong. I didn't realize this until over an hour of adjustments.
Other than that, it was pretty straight forward. Your hex size may be different than mine so you may have to experiment with that a bit. I am going to drive it a bit before I try to adjust the actuator arm so that I can get a little bit of data before I start making finer adjustments. But for now the car runs excellent. I can run all of the engine output tests without the car dying, and I can run the basic settings for the EGR without the car dying now. The specs per VCDS are within the parameters all around the sensors that I have checked.
One thing that I have noticed so far is that in VCDS under engine, measuring blocks, number 11 the specified boost vs. actual boost is off by about 150 mbars at idle up to about 2000-2500 RPMs in park or neutral.
I can't remember what they were before but right now specified is 999 mbars and actual is around 865 mbars. VCDS says that it should be between 900-1100 on both spec. and actual. Anyone know if that is OK or if I should adjust something to put actual boost at idle closer to specifications?
By the way, a good way to test your vacuum lines and your n75 system all together is to get a vacuum tee and a $3.00 6 foot section of small vacuum hose(same size as the vacuum hose going to the turbo actuator). Cut a small piece of vacuum tubing about 2 inches or so and place it on one end of the tee, put the other end on the turbo vane actuator and put a vacuum gauge or in my case a mityvac on the 6 ft. hose so that you can route it somewhere where you can see it while the engine is running. If everything is working correctly there should be around 20-23 psi of vacuum and as you accelerate the psi will drop depending on how much the ecu and n75 is demanding. The more the acceleration the more the drop towards 0. I believe BEW engines are opposite, or maybe ALH's, either way mine is a BRM. Anyways, saved me from buying an n75 valve, as I thought that was my problem. Also, Autozone rents mityvacs for free upon return.
Anyways, if anyone needs any information or logs of my experience, let me know. And thanks for the info from everyone on this thread from jsrmonster to DanG144 and Jnitrofish. This one had me stumpted, and I refuse to throw cams, n75 valves, turbos, MAF's or any other part that the dealers have been installing to try and fix this problem. I'll post any updates if I decide to tinker with the actuator arm.
Thanks again,
Wade
