NothernSky
Hi!
I made a search and didn´t find a tread (but I remember it was) about someone adding the Oil Pan with sensor integrated, I have the MFA Cluster and I know it will work cause was coded from factory that way. /images/graemlins/grin.gif
I know is simple cause one cable is ground and the other goes to the cluster but I think only works with the Imperial english coding.
Check this part: Oil Pan With Oil Level Sensor And Drain Plug
