Old May 15th, 2003, 13:22   #1
davran
Default Pennzoil Synthetic 5w-40 VW505 rated oil:
You may all already know this, but I came-across an oil that is VW 505.00 approved.
Pennzoil has a Synthetic 5W-40 that's fully VW 505 rated. I found it at my local Jiffylube, and was told all of them have it. The can has a yellow star on it saying "European Formula".
Tootles,
David
davran is offline   Reply With Quote
Old May 15th, 2003, 18:10   #2
00sierra
Fuel Economy: 49 MPG
Who knows some more about this oil? I am getting discouraged because I can't find Delvac 1 anywherer around here. I've bee to about 8 places. No luck.
00sierra is offline   Reply With Quote
Old May 15th, 2003, 18:28   #3
dieseldorf
top post dawg
dieseldorf's Avatar
well, this issue just cam up yesterday and the oil kinda meets a TDI's needs.
Here's the spec sheet: pdf link
Old May 15th, 2003, 19:19   #4
FowVay
FowVay's Avatar
It says that it meets ACEA B3 and VW 505 so it should work. It's probably a similar formula to the Valvoline SynPower 5W-40 and the Quaker State Euro formula. These oils aren't the best for the TDI but they'll probably provide years of excellent service.
FowVay is offline   Reply With Quote
Old May 15th, 2003, 21:20   #5
davran
I don't understand. If VW wants an oil used that's VW505, and this oil is VW505, why isn't it the best for TDI engines?
I don't know that much about oils, and would like to know what would be better.
Thanks,
David
Old May 15th, 2003, 22:09   #6
tjl
Fuel Economy: 55/52/47 (mpg)
It could be the best, or it could be not the best (same goes for any other oil of the viscosity and ratings listed in the manual). Either way, it should be good enough for use in a TDI engine in typical service at the specified oil change intervals, since it meets at least one of the manual specifications.
tjl is offline   Reply With Quote
Old May 16th, 2003, 15:47   #7
troy_heagy
BANNED
[You can find Delvac1 locations at mobil.com]
HA I love it!
Volkswagen says, "Use VW 505.0 rated oil." (like Castrol and this new Pennzoil)
and the guys here say, "No! No! No! VW doesn't know what it's talking about. That oil's not good enough!"
No offense guys, but I think the VW engineers are most qualified to say, "VW505.0 oil is good." Although I prefer Delvac1 because it's easy to find and cheaper, I don't think anyone's going to kill their TDI if they use the VW505-rated Castrol or Pennzoil.
troy_heagy is offline   Reply With Quote
Old May 16th, 2003, 15:59   #8
Vectorer
Vectorer's Avatar
Yes...but, does it have Z-7?
Vectorer is offline   Reply With Quote
Old May 16th, 2003, 16:24   #9
dieseldorf
top post dawg
dieseldorf's Avatar
Group III (acceptable) versus Group IV (more than acceptable)
It's that simple.
Old May 17th, 2003, 09:58   #10
troy_heagy
BANNED
What is that?
Old May 19th, 2003, 22:57   #11
Dave_Robson
File Z-7 under the same heading as "liquid ball bearings" (another Pennzoil marketing gimick).
Dave_Robson is offline   Reply With Quote
Old November 12th, 2018, 10:27   #12
davran
This is the 505.01 oil I found locally and am using (Motul x-clean 5w40):
https://www.motul.com/us/en-US/produ...0-x-clean-5w40
07/2004 Passat B5.5 TDI wagon
WVWCE63B65E021878
Old November 12th, 2018, 15:23   #13
Dannyboy
Dannyboy's Avatar
Fuel Economy: All good on the motion lotion
Wow. 15 year revival that must be close to a record
Dannyboy is offline   Reply With Quote
Old November 16th, 2018, 15:48   #14
Ol'Rattler
Ol'Rattler's Avatar
That is amazing. The tip off should have been that the OP referred to the oil being sold in a can.
I did check Penzoil's Euro recent offering and it doesn't actually have a VW approval, just a recommendation by Penzoil as usable in the place of VW 502.00 and VW 505.00. The way they listed it was pretty crafty. The specifications, approvals and recommendations are in one list. The only actual approval listed is for MB.
https://www.pennzoil.com/en_us/produ..._Motor_Oil.pdf
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old November 16th, 2018, 15:56   #15
Ol'Rattler
Ol'Rattler's Avatar
I found this site that is a cornucopia of knowledge about oil specs.
https://www.oilspecifications.org
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Page generated in 0.17754 seconds with 10 queries
[Output: 118.92 Kb. compressed to 98.41 Kb. by saving 20.50 Kb. (17.24%)]
