Hi guys,
need some help now, or my car will get dumped at the wrecker......
Started in the summer converting my PD 100 ATD to PD150 using a NEW Garret GT1749VB, a set of second hand but perfect running ARL PD injectors, upgraded SMIC and EGR delete kit.
Mounting the pieces were no problem, and when i first started the car it was only some small smoke for like 10-15 sec, and only one fault code due to the removed EGR valve.
Then I went to work (offshore) and were away for 6weeks and the car were not touched. When I came home and started it, I noticed it were making alot of smoke when ideling(grey/white, smells a **** load of diesel). Kept the engine running to get warm, but the smoke didnt go away. Looked around on the interwebs and made a conclusion that it must be either the wiring loom for the injectors or the injector itself who is causing the trouble. Both were changed, but nothing changed...
Found this thread witch seems to be pretty mutch the same problems, but cant find any solution.
http://www.bba-reman.com/forums/Topic130712.aspx
Can someone give me some pointers on what to check next? Getting sic of the car now
best regards!!
best regards!!
