Old October 28th, 2018, 16:23   #3481
Mrrogers1
Fuel Economy: Never high enough but always trying for more.... (See signature)
Originally Posted by Dannyboy View Post
Oh dear, doesn't look good. Emissions recall isnt agreeing with it. Emission recall done at 51k kms
3rd oil sample dealers gave me wrong oil. 2009+ oil apperently is a bit different
The 2009+ oil is 507 spec so it should have been the same. Now, the 2006 oil was 505 spec and definitely different. Next UOA should be interesting, wondering what's going on there.
Mrrogers1 is offline   Reply With Quote
Old October 28th, 2018, 16:32   #3482
tdiman
tdiman's Avatar
So do u think maybe u got someoneís else oil ?
tdiman is offline   Reply With Quote
Old October 29th, 2018, 00:42   #3483
CleverUserName
New to me '03 Golf TDI. Got it about a month ago from the 2nd owner and 167K miles. Really like it, however it's too small. I'd prefer a Jetta or Wagon instead.
47 MPGs average combined hand calculated on 2 fill ups.
Needed an Oil Change and Fuel Filter. I also replaced the fuel supply/return lines from the filter to the IP as they were showing their age. Other than that it is very clean and well maintained vehicle.
Engine is basically stock except a Malone Stage 2 tune and Bosio PP520 nozzles.
The PO has reduced EGR flow using adaption function in VCDS.
Report says D1 ESP however it's M1 TDT, CJ-4 version. Surprisingly this is the same wear profile I've seen when using D1 in my 2.8 Duramax. Overall the wear report is really good considering the EGR system is functional. Hard to believe, really... I took the sample mid-drain.
Re-filled with RLI Biosyn CJ-4, it's a 50/50 blend of 10w30 and 15w40 + 2% Booster pak = 10w40. Replaced the Mann with a Bosch Premium filter. I don't think RLI can outdo ESP or TDT but we shall see...
CleverUserName is offline   Reply With Quote
Old October 31st, 2018, 16:49   #3484
James & Son
TDI(s): 2006 Jetta
CleverUserName,
If you are trying to reduce or beat the TDT UOA you could probably easily do it with Bio-SynXtra HD SHP Motor Oil SAE 5W40 (10 TBN). To reduce iron wear you need the 185 VI which is attained without exccessive use of VI index modifying polymers which improves HTHS and flash point.
Thats likely what you were after with your combination and mix. But you lose out on the benefit of increased flow and reduced wear at startup. The other benefit at start up of all RLI products is the improved boundary or lubricity during start up and shut down.
The difference between Bio-SynXtra HD SHP Motor Oil SAE 5W40 (10 TBN) and the low ash version is a reduction in the amount of antiwear and TBN to attain the latters low ash( equal to CJ4). The advantage of the former( equal to a CJI) is you have the additional additives already and unnecessary use the 2% adder pack.
Just in case your interested I use the low ash 5w-40 and drive one year or 15000 miles, at month (6) I add 2% and then at month (9) I add another 2% in hope that I retain the CJ4 low ash qualitys without deminished wear additives.
I would expect with your '03 you would likely get to 15000 miles with no additives using the Bio-SynXtra HD SHP Motor Oil SAE 5W40 (10 TBN).
One of the reasons you can run the RLI out passed 10,000 miles is its tolerance for diesel fuel dilution.
James & Son is offline   Reply With Quote
Old October 31st, 2018, 19:41   #3485
CleverUserName
Originally Posted by James & Son View Post
CleverUserName,
Hi, James & Son.
I had two bottles of the booster pak which were ordered about a year ago. I am just using them up, 1/2 bottle (4oz) in my Golf and 2.8 Duramax at each OCI. I do not plan on buying anymore booster pak.
I created this mix of 10w30 & 15w40 because I got a bunch of the 10w30 CJ-4 for cheap and wanted to thicken it up a little. The 15w40 has great properties (Low NOACK, High VI, and High FP) so it seemed like the best option.
I had this "10w40" blend tested by Oil Analyzers, it is a "thin" 40wt and it has a VI of 172.
  1. 78.8 cSt @ 40c
  2. 13.3 cSt @ 100c
  3. NOACK 8.5% (11% + 6%/2 = 8.5%)
  4. 526 ppm of Sb
  5. ~1100 ppm of Phosphourus
As you can see it has superior cold flow (40c) properties at the mild temperatures we see here in CA. I don't need a low winter rating so 10w, 15w and even SAE 30 are fine here.
These higher winter rating blends use thicker base oils so the flash points are typically higher than a 5w.
I'm staying with the low-ash versions because I'm also using this in my 2.8 Duramax equipped with emissions controls. The 10 TBN CI-4+ version of the 5w40 is excessive SA. I also would be changing the oil once a year anyway so I don't really need to exceed a 10k mile interval as I have two vehicles. CJ-4 is fine for me.
I would also like to mix the 15w40 with the SAE 30 next as that would be even a lower NOACK (6.5%) and higher flash point. That is the next thing I will try if the Oil Analysis results are better than what I've seen with TDT and D1 ESP CJ-4 versions.
I'm attaching a copy of the OAI report for your reference:
Old November 1st, 2018, 21:38   #3486
Mike in Anchorage
Mike in Anchorage's Avatar
Oh dear, doesn't look good. Emissions recall isn't agreeing with it. Emission recall done at 51k kms
3rd oil sample dealers gave me wrong oil. 2009+ oil apparently is a bit different
Why would the molybdenum values change so dramatically? That would concern me more than the sodium, I would think.
~ ďI'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best.Ē Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
Old November 2nd, 2018, 15:17   #3487
TornadoRed
TornadoRed's Avatar
Molybdenum is an anti-friction additive. Some motor oils have a lot of it, some have a little, and some have none. Also, for those who want more, there is this>>>
'03 Golf with 785k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat fuel filter with Nicktane head, DG Panzer w/FMJ, Blizzaks, Delvac1
Become a TDI Club Contributor. http://forums.tdiclub.com/payments.php
Old November 4th, 2018, 07:55   #3488
James & Son
TDI(s): 2006 Jetta
Originally Posted by CleverUserName View Post
Hi, James & Son.
  1. 78.8 cSt @ 40c
  2. 13.3 cSt @ 100c
  4. 526 ppm of Sb
Looking forward to those results. Your anti-wear numbers, antimony and phosphorous together are 170% more than TDT's phosphorous. This along with the natural
esters your iron wear should drop. If your engines are in good shape I would reduce the Sb to 2 ounces unless the duramax needs it for some reason. The 30% natural esters help the lubricity due to their affinity for steel surfaces.
Old November 12th, 2018, 15:46   #3489
Dannyboy
Dannyboy's Avatar
Fuel Economy: All good on the motion lotion
Good eye. I forgot that I had a quart of ESP Mobil 1 507 and dumped it in , so it skewed the reading a bit from dealer oil.
I bought dealer oil from the first oil change, now I've decided to go a different route but staying to the VW507 spec to see if it helps.
Dannyboy is offline   Reply With Quote
Old December 15th, 2018, 14:35   #3490
03TDICommuter
First time ever for a UOA for me on any of my cars.
2003 Jetta TDI, 5 spd, 360K miles, original engine/turbo
- 319,300 miles - turbo vanes cleaned, replaced control ring
2019 e-Golf SE, quiet and smooth!
03TDICommuter is offline   Reply With Quote
Old December 15th, 2018, 17:47   #3491
Wankel7
Wankel7's Avatar
https://imgur.com/a/UDsox8R
What has changed about T6?
2003 Jetta Wagon 5 speed
DLC520, Audi Avant Rear Wiper, .658 5th gear, FX-R HID Retrofit, Philips DRL9 , Atlas skid plate, trailer hitch, ventectomy, Half FIS Euro Cluster, Frostheater, ceramic tint, Scangauge II, and EGR deleted.
VCDS -HEX/CAN & VagTacho available
Wankel7 is offline   Reply With Quote
Old December 15th, 2018, 22:10   #3492
CleverUserName
I think this is the first UOA Iíve seen on the CK-4 version of T6 being used on a flat tappet 1.9.
Notice the lower concentration of ZDDP. Old CJ-4 T6 was around 1200 ppm.
Molybdenum is gone as well. Different ratios of mg & ca.
Viscosity is in a 50 wt now due to soot or oxidation. More comprehensive testing could find out why it thickened up 2 cSt.
TBN is kinda low too.
Based on TBN retention in my prior UOAs using CJ-4 Mobil TDT and Delvac ESP in multiple diesels, I think both would easily last 20k miles. I donít think this new T6 would hold up much longer than 12k based on this report in this vehicle.
Wear numbers are OK but generally not very impressive. UOAs with T6 have never blown my socks off.
Old December 16th, 2018, 06:41   #3493
TornadoRed
TornadoRed's Avatar
And that's fine for most ALH and PD drivers, who tend to stick with 10k-mile oil change intervals. Even with TDT and Delvac 1.
Old December 16th, 2018, 09:44   #3494
turbobrick240
turbobrick240's Avatar
Looks like a great report! The sky is always falling for some folks when formulations change. Clearly the new CK-4 stuff is great lubricant and protecting your engine well.
Old December 16th, 2018, 09:49   #3495
tdiman
tdiman's Avatar
Default TDI Used Oil Lab Analyses Results & Discussions
Just trying to figure out how to post results how are you up loading
Page generated in 0.56935 seconds with 12 queries
[Output: 139.29 Kb. compressed to 117.40 Kb. by saving 21.89 Kb. (15.72%)]
