ItAintRodKnock
Hey guys, i am slowly converting my MK4 Golf into a sort of Overlander vehicle.
I dont intend to do a tent ontop, but i would like to do a longer(than usual) metal basket and have Triple Row LED Light bars on all four sides.
I envision a 42" hanging from the front.
a 20" mounted in the rear.
four 4" pods, two mounted on each side(Driver and passenger)
This will be in addition to the 26" i have mounted under grill, in the bumper.
Each will be on a rocker switch mounted in the dash, so 4 switches in total.
What I am interested in, is finding a strong 12V source for each setup.
I am curious if an Aux. Battery is an option?
A smaller battery, that recharges like my cranking battery, but the load of the lights can go through there. To not put to much of a draw on the Alternator, or cranking battery. Is that proper logic?
OR
Run through open circuits in the fuse panel on the drivers side?
The 4 small lights can run off almost any circuit. The larger 42" needs to be pretty heavy duty, fuse wise. The 26" is currently ran off the battery Positive, and ground to the Chassis.
The 20" being the one left, I'd assume i could go off anything on the fuse panel with that too.
Is it as simple as, Draw Positive from there(Adding a fuse in the open space) and running it to my Relay and Light as needed?
Can any open circuit in there run a 5a, 10a or 15amp fuse?
thanks for the help guys.
OR
