TheRagnarok
So I just bought a 2006 TDI Jetta 5-speed with 208k miles for $2400 (talked him down from $3k)
When I start the car after it has warmed up I get a puff of white smoke from the exhaust.
And a few times the engine would stop mid crank on start.
Basically it would fire then stop, but will start on the next crank.
This is an intermittent problem (about 60% of starts)
Fixes/Problems:
-Oil pan was leaking steadily so I patched the hair-line crack with JB-Weld.
(Going to put in a new pan soon)
I now have to trace down a very small leak on the back of the motor.
(Possibly valve cover or tandem pump gasket)
-Timing belt change (dieselgeek kit)
I am working on getting a Vag Com to check timing. And leaning towards this causing my smoke issue.
-Hose to from the vac tee to the brake booster was split. (turbo was not actuating and the brake booster was not working) easy fix
-Performed a diesel purge/changed fuel filter.
-Disassembled the drivers door actuator and lubed it up (PO had put a rubber band on it in an attempt to fix lol)
Fixes/Problems:
