Old July 3rd, 2019, 14:56   #1
zzdiesel
Default Instrument cluster
If replacing with a used one,is there any need for reprogramming? Immobiliser?
2005 B5.5 TDI
zzdiesel is offline   Reply With Quote
Old July 3rd, 2019, 18:05   #2
QuickTD
2005 B5.5 TDI
Yes. Half the immo is in the cluster. Unless you know the pin of your present cluster and the replacement, you'll need to see the dealer or a locksmith or someone with specialized tools to code it. You'll need to bring all your keys to complete the process. The car will be undrivable once you replace the cluster, so you may want to bring tools and swap it in the dealer lot.
QuickTD is online now   Reply With Quote
Old July 4th, 2019, 09:49   #3
zzdiesel
Thanks Quick,
I will not change the cluster then. It is just for the LCD display which fades as it warms. Irritating.
Old July 11th, 2019, 15:38   #4
DeliveryValve
... It is just for the LCD display which fades as it warms. Irritating.
I have the same issue. Found the replacement LCD, but not confident in my skills to actually do the replacement.
So I found this outfit to possibly send my cluster to. They'll even polish the lens.
Does anybody have any experience with this place?
https://www.speedosolutions.com/LCD-...ster_p_39.html
- Richard-
2005 Passat TDI GLS Wagon 21x,xxx miles - Chainless
DeliveryValve is offline   Reply With Quote
Changing the instrument cluster to the MFA cluster pkhoury VW MKIV-A4 TDIs (VE and PD) 4 May 27th, 2016 12:13
Jetta 5 2.0TDI beeping instrument cluster and flashing cluster lights. HELP PLEASE!!! B40RK@D VW MKV-A5 Golf/Jettas 9 January 24th, 2016 19:58
Need Some Instrument Cluster Help Mr_Deezy TDI 101 2 January 17th, 2012 14:33
Instrument Cluster CinCityJetta VW MKIV-A4 TDIs (VE and PD) 4 July 11th, 2007 23:50
Instrument cluster Kamera VW B5 Passat TDIs 0 August 23rd, 2006 13:05
Page generated in 0.13936 seconds with 12 queries
[Output: 63.27 Kb. compressed to 56.78 Kb. by saving 6.49 Kb. (10.26%)]
