Thanks for your reply. Any idea what would be leaking above? Oil filter housing?I have never heard of oil migrating upwards - except when a high pressure leak occurs, pushing the oil violently upwards. I had this happen on my van when my oil filter was attached incorrectly, spraying oil upwards from the bottom of the engine.
In this photo, it sure looks to me like the oil is leaking down.
I would replace the oiler cooler with a larger one and a longer rod/retainer thing. The engine oil gets up to normal temperature faster and your FrostHeater (if installed) would warm more of the oil before starting the engine.ok i have a 99.5 jetta tdi , i understand that part, but i replaced both seals just under a year ago, purchased from idpart.com, what are the odds that the top seal would go bad again in such a short time? btw when i installed them, i didnt lube up the top seal just the bottom because that one spins as you tighten it and the top just gets squeezed up, could that be my problem , should i have rubbed a little bit of oil on both seals before installing? or could i have over tightened it?
btw just wondering before i replace just the seals, at what mileage should the oil cooler be replaced completely, as preventative matenience?
I just tightened up the nut on the bottom of the cooler and it stopped leaking. I never replaced the seals. 6 months after I posted this/tightened it it's not leaking still.
