dzlchef
My 2002 Jetta has been very tough to start recently. After the car sits overnight, it takes 3 or 4 times cranking the engine before it will turn over. The engine runs fine once it is started and it will restart instantly during the day as needed.
I have checked my air filter and the snowscreen was recently removed. The engine is receiving air as far as I can tell, my question is if the problem is fuel related (ie, fuel filter, pump, etc.), and what things do I need to check out or replace?
Thanks for any constructive input. I've searched for threads on this subject without much luck.
