Fuse Location
thundershorts
west chester pa
2015 passat tdi sel premium 2015 golf s tdi gls tdi b5.5, 2002 eurovan,Peugeot 505 td,Citroen cx25 prestige
its in the relay panel. lighter sockets wear out as well
eyetdiman
Wilmette, IL
'04 Passat TDI Sedan
Fuse Location for Front Cigarette Lighter on an '04 TDI Passat Sedan
I found it.
The fuse is in the main fuse panel (on left side of the dash next to the drivers door..the cover is on tight so you may need to pry it off with a screwdriver), about in the middle of the panel..15 amp.
