Old July 15th, 2012, 05:42   #1
the.tdi.kid
Fuel Economy: 48
Default Cv bolts backing out helppppp
alright guys as the title says, the cv bolts keep backing out on the drivers side. this is not the first time. last time this happened, the cv came around and popped a hole in the tranny. luckily i caught it this time before that happened again. what is going on and why does this keep happening? help is much needed, otherwise I'm gonna be forced to leave the tdi world
the.tdi.kid is offline   Reply With Quote
Old July 15th, 2012, 05:46   #2
gquenstedt
Did you use all new bolts? Obviously you lost the ones in there but just making sure you didn't reuse some you had. Did you use a torque wrench to tighten them?
Check out my website: www.gqlaw.us
gquenstedt is offline   Reply With Quote
Old July 15th, 2012, 05:50   #3
RabbitGTI
RabbitGTI's Avatar
Fuel Economy: Don't know. I just feed it and drive.
Degrease everything. Use loctite and a torque wrench.
Rabbit GTI racecar RIP, 84 Rabbit GTI (dormant), 88 Golf GL (crushed), 97 Passat TDI (retired), 07 Jetta 2.5, 02 Beetle 2.0, 08 Jetta 2.5 with Aisin Box.
RabbitGTI is offline   Reply With Quote
Old July 15th, 2012, 05:51   #4
the.tdi.kid
Fuel Economy: 48
i used all new hardware, brackets and bolts, got them from vdub
Old July 15th, 2012, 05:51   #5
the.tdi.kid
Fuel Economy: 48
what are the torque specs?
Old July 15th, 2012, 06:09   #6
PeterV
HO5G Doyen & Zen Master
PeterV's Avatar
Bentley says 30 ft lbs.
do you still have the lock plate installed?
The manual IS important you should not attempt repairs unless you have all the info you need.
PeterV 'BUG*pwr award 2005'
'00 Jetta TDI, RC, Shine, DG RPipe, 520PP, DG/SS LED Boost ASR. Home of HO5G ('96 Cummins CTD 3/4 ton now at 274 HP 670 ft Lbs TQ riprust) Ram 1500 hemi
Trusted TDI Mechanics Map || VCDS Locator ||
PeterV is offline   Reply With Quote
Old July 15th, 2012, 06:13   #7
PeterV
PeterV's Avatar
you should have 3 lock plates.
Old July 15th, 2012, 06:43   #8
the.tdi.kid
Fuel Economy: 48
all three lock plates were there
Old July 15th, 2012, 07:28   #9
Drivbiwire
Zehntes Jahr der Veteran
My guess you got a new drive shaft, did not install the balancing donut, have a cheap aftermarket shaft that is out of balance, and the combination of those factors is vibrating the bolts loose...
Solution new OEM shaft with OEM balancing donut!
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old July 15th, 2012, 08:03   #10
Niner
duplicate account, banned
/\ this... you can't just swap out C.R.A.P. parts on a tdi.
Niner is offline   Reply With Quote
CV Joint Bolts - TTY or not? Sooch TDI 101 19 October 4th, 2014 11:17
Cv shaft bolts wkobe VW MKIV-A4 TDIs (VE and PD) 13 December 7th, 2010 14:07
Safety-wire CV bolts? CFM TDI Power Enhancements 12 April 30th, 2010 17:56
Intake manifold bolts backing out? Thermo1223 VW MKIV-A4 TDIs (VE and PD) 8 November 7th, 2007 17:38
OMI bolts keep on backing out!!! 20IndigoBlue02 TDI Power Enhancements 2 July 23rd, 2006 01:18
Page generated in 0.16171 seconds with 11 queries
[Output: 95.02 Kb. compressed to 80.51 Kb. by saving 14.51 Kb. (15.27%)]
