BOSTON-VW
I can't seem to find a K&N Air Filter for my 2009 Jetta TDI. I found some 2008 2.0L Air Filters. Not sure it's for a diesel. Does anyone have any insight?
Thanks in advance!
Alex
Thanks in advance!
Alex
You are lucky. They are known for damaging your MAF. Unless you have made some serious modifications, you will not gain any additional power or mileage using one, but you will risk damage. Don't use K&N air filters. (Note this advice only applies to the more common oiled versions.)BOSTON-VW said:I can't seem to find a K&N Air Filter for my 2009 Jetta TDI. I found some 2008 2.0L Air Filters. Not sure it's for a diesel. Does anyone have any insight?
Thanks in advance!
Alex
Yes...You're correct! I'm a total newbie! Thanks for setting me straight the both of you! I'm glad I asked! I'm digging my new Jetta TDI. Getting use to the diesel in general. The 6-Speed isn't like my 2003 GLI at all. I like it just the same.2004STARWARSTDI said:I can tell your a newbie because you did not do a search on K&N air filters. A K&N air filter or any oiled air filter will ruin your MAF! MAF cost $$$. Void your Warranty! Does no improvement to a TDI. Do a search and you will find the facts. The original paper filter does an outstanding job!
Hey, don't get hysterical! I've had a K&N on my Hyundai for the past 30K miles, and it works just fine. No problems with the MAF sensor either.2004STARWARSTDI said:I can tell your a newbie because you did not do a search on K&N air filters. A K&N air filter or any oiled air filter will ruin your MAF! MAF cost $$$. Void your Warranty! Does no improvement to a TDI. Do a search and you will find the facts. The original paper filter does an outstanding job!
Don't forget that because a diesel engine is a very high compression engine, it sucks in far more air than a gas engine does. The little bit of oil mist coming in on a gas engine may not damage the MAF, but the more air that comes in, the more oil mist comes in too.mrchaotica said:Hey, don't get hysterical! I've had a K&N on my Hyundai for the past 30K miles, and it works just fine. No problems with the MAF sensor either.
However, I wouldn't get one on a TDI, because (just like with any turbocharged engine) the turbo compresses the intake air to a constant pressure regardless of how restrictive the filter is (within reason, of course).
Internet studder!jasonTDI said:The factory air filter flows way more air than the can can ever use.
velociT said:Internet studder!
I dont feel like arguing, so... the factory crap paper filter outflows any performance filter.
Using a K&N filter will cause the large hadron collider to malfunction, creating a black hole which will surely kill us all.
We have the same air filters used in the 1.8T and both VR6s (2.8L and 3.2L). I suspect they pull much more CFM than our TDIs. THAT is the point folks are trying to make. The OEM filter far exceeds the needs of our engine. Folks making over 300 ft-lb and 200 HP are using the stock air filtervelociT said:Internet studder!
I just got done removing the stock airbox-filter assembley on my 2009 sportwagen and fabricated a new intake tube -highflow washable filter. I went light on the oil for the filter. The differance is absolutely amazing. I feel like I picked up 50 hp. The car requires much less throttle application than with the stock airbox. This is a must do mod. I cracked a smile I could not wipe off during the 1st roadtest. I will advise of mpg +/- in the next couple of days. You doomsayers know not what you speak of.Revolutionary_mind said:Nothing more annoying than K&N fanboys at the local autozone raving about how they got 10 more hp and 5mpg.
If you want more flow, or just to feel like you have more flow, upgrade the airbox/intake tubing, snorkel, etc.
It's Rocket Surgery. Sorry. I Couldn't resist. Continue.40X40 said:It doesn't have to outflow 'any performance filter'.
It just has to outflow the damn engine. Which it apparently does with ease.
What is so hard about this concept?
It is not rocket science....
Bill
Paper filter fanboys in 3..... 2..... 1......Brian.Burress said:It's Rocket Surgery. Sorry. I Couldn't resist. Continue.
Although, I agree with the K&N being crap (the oiled ones), I do believe that the AEM Dry Filter is a very good filter. By just looking at the intake piping of the AEM compared to the squished down piping of the stock, I would say it has to flow more air, but if the stock already "outflows the damn engine", then maybe more air would just be money wasted.
-Brian
__. That's a *perfect* recommendation. It's the oil that catches the abrasive dirt particles. A K&N already lets a LOT more dirt through the filter than paper ... yeah, cut down on the oil. Make a poor filter even worse. What kind of critical thinking is going on here???????LILALLEYKATT said:(snip) Go light on the filter oil.
LILALLEYKATT said:I just got done removing the stock airbox-filter assembley on my 2009 sportwagen and fabricated a new intake tube -highflow washable filter. I went light on the oil for the filter. The differance is absolutely amazing. I feel like I picked up 50 hp. The car requires much less throttle application than with the stock airbox. This is a must do mod. I cracked a smile I could not wipe off during the 1st roadtest. I will advise of mpg +/- in the next couple of days. You doomsayers know not what you speak of.
ToolNut said:Forgive me, but I've always thought that a free-flow air filter was used primarily for hi-rev engines to help breathability at the top end. Why would it be needed for an engine that only revs to 5K? And turbocharged at that?
Confused...
