Old September 25th, 2012, 06:53   #1
sosnpk
Default No start, No dash lights, no power windows
Car died while driving and wouldn't restart, luckily near my house.
1) Engine cranks but no start.
2) No glow plug light (tried couple or relay 109, no good)
3) Wipers work okay
4) No turn signals
5) No power windows
Thinking ignition switch burned out but also wanted to put this out there to see if other relays or fuses should be checked so i can pick those up too, just in case.
sosnpk is offline   Reply With Quote
Old September 25th, 2012, 07:25   #2
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
Thumbs up
Was this a sudden failure?
All those systems at once?
If so, I would buy an ignition switch; they are cheap enough, and common enough of a failure that if this test doesn't work, you can keep it in your parts bin for the impending failure!
  1. Remove the steering column covers
  2. Unplug the original switch
  3. Plug in the replacement switch
  4. Using an appropriate sized straight blade screwdriver, turn the switch as you would with the key.
  5. If the accessories work, the switch needs to be replaced.
    1. There is a stick for ignition switch replacement at the top of the A3/B4 section
If each of the systems failed one at a time, over time, I would chase the fuses and relays.
I would wager that the ignition switch is the culprit.
Tony
Diesel fleet: '15 Jetta TDI SE; '06 Jetta, TDI, DSG-5sp Conversion; '06 DC Cummins, CC/LB/DRW; Past Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old September 27th, 2012, 07:58   #3
sosnpk
Got it going again. Was the ignition switch. All systems back up and running. This switch was only in service for about 6 months.
No Power WIndows, Or interior Lights! HELP!! 1tdi VW MKIV-A4 TDIs (VE and PD) 5 August 12th, 2010 22:22
no alarm, no interior lights, no power windows?? 4lowdubs TDI 101 3 December 2nd, 2008 09:42
no power windows, locks, interior lights? boogenman TDI 101 5 November 19th, 2008 08:37
Won't start...no power to locks, trunk, windows, interior lights and sunroof. psychadila TDI 101 26 April 28th, 2008 13:12
No dash lights and no start!!! Help!!! jdevink VW MKIV-A4 TDIs (VE and PD) 14 March 31st, 2005 17:52
Page generated in 0.17562 seconds with 11 queries
[Output: 58.67 Kb. compressed to 53.47 Kb. by saving 5.20 Kb. (8.86%)]
