Biodezl
After replacing the heater core of my son's 1999.5 Golf TDI and putting everything back together, there are two error codes reported by VCDS (plus several others related to the central locking system -- the complete log file is below), the airbag light is illuminated as well as the MIL. The airbag problem is a known issue--my son broke the wiring harness when pulling the airbag off the steering wheel, but I don't know what to think about the P1694 error. Is it a real problem, or is it just saying the MIL is illuminated because the airbag system is not happy?
We're going to buy a new wiring harness.
Any clues what I should (or should not) do about the other error code?
Thanks!
-BIODEZL
Sunday,10,July,2016,13:17:20:39245
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
Mileage: 302140km-187741mi Repair Order:
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 302140km-187741miles
Address 01: Engine Labels: 038-906-018-AGR.lbl
Part No: 038 906 018 EB
Component: 1,9l R4 EDC G460AG 2143
Coding: 00001
Shop #: WSC 01317
VCID: 5AB56310C68634EE50-4A82
1 Fault Found:
18102 - Malfunction Indication LightK83)
P1694 - 35-10 - Open or Short to Ground - Intermittent
Readiness: 0 0 1 0 1
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 EF
Component: AG4 Getriebe 01M 4093
Coding: 00011
Shop #: WSC 00011
VCID: 78F11998584A06FE46-0950
No fault code found.
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 G
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 01317
VCID: 356FD0AC0FD83B969D-4A82
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: C AIRBAG VW3 SG 0002
Coding: 00067
Shop #: WSC 01317
VCID: 6CD935C81C12BA5EB2-4AB4
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance Too High
Address 17: Instruments Labels: 1J0-919-xxx-17.lbl
Part No: 1J0 919 951 A
Component: A4-KOMBIINSTR. VDO V01
Coding: 06242
Shop #: WSC 00000
VCID: 2E5DFFC0EA8E084EDC-50C8
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 60 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 26111
VCID: 060D676022BE600E44-4A82
Subsystem 1 - Part No: 1J1959801C
Component: 60 Tõrsteuerger. FS0001r
Subsystem 2 - Part No: 1J1959802D
Component: 61 Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 60 Tõrsteuerger. HL0001r
Subsystem 4 - Part No: 1J4959812C
Component: 60 Tõrsteuerger. HR0001r
6 Faults Found:
00949 - Central Locking Motor - tailgate (V53); LOCK
25-10 - Unknown Switch Condition - Intermittent
00953 - Interior Light Time limit
01329 - Convenience System Data Bus in Emergency Mode
35-10 - - - Intermittent
01332 - Door Control Module; Passenger Side (J387)
53-10 - Supply Voltage Too Low - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
01334 - Door Control Module; Rear Right (J389)
End-------------------------(Elapsed Time: 04:56)--------------------------
Thanks!
-BIODEZL
www.Ross-Tech.com
76
Coding: 00001
Shop #: WSC 01317
1 Fault Found:
Coding: 00011
Shop #: WSC 00011
Coding: 03504
Shop #: WSC 01317
Coding: 00067
Shop #: WSC 01317
1 Fault Found:
Coding: 06242
Shop #: WSC 00000
Coding: 04096
Shop #: WSC 26111
6 Faults Found:
35-00 - -
