Old March 13th, 2015, 06:40   #1
Default AdBlue: tank consumed in 4,000 miles?
Long time reader, very infrequent poster. Here goes...
I have a 2013 Passat TDI SE with about 65,000 miles on the clock. It's been very methodically maintained by my dealer at each interval. Up until now, I hadn't even touched the DEF/AdBlue port - the dealer filled it at each 10,000 mile service. They top it off and of course charge me now that the initial warranty is up.
At around 48,000 miles (last summer) my turbocharger blew up. This was *right* after the warranty extension letter came in the mail. I had the same dealer make the repairs. I described this in the appropriate thread for the sake of science...
From about 45,000 to 60,000 I began to put the car in a different type of service... Uber/Lyft driving. This is like any other livery service... lots of city use, starts and stops. I try to limit idling as much as practical (no more than a minute or so.)
Only at around 60,000 miles did I receive my first low AdBlue warning. The dealer topped of the DEF at the scheduled service, no problem, all is well, right?
At about 63,800 I received another AdBlue warning. It ominously did the "starts will be disabled" countdown. Surely enough, the tank was dry. I bought the appropriate filler bottle and a 2.5 gallon jug and refilled it myself.
Sorry for the novel, but my question - would one really consume a tank's worth of DEF in under 4,000 miles, even with part-time livery driving conditions? I mentioned it to my service advisor and his response - "it will vary based on driving conditions." He mentioned some of the Touaregs gulp the stuff.
Maybe they just didn't fill the tank completely at 60K? Is it related to age? New turbo? Wondering what others have experienced.
(PS I'm pretty much done abusing my car for livery, but I wanted to try it out. The Passat is wonderful for it, but it doesn't compensate me enough to wear down a beautiful car.)
inderwies is offline   Reply With Quote
Old March 13th, 2015, 07:58   #2
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
A full tank should last over 20k miles averaging low 40mpgs (adblue usage should be proportional to fuel). 2.5gallon (or 5 if it was full!) in 4k miles sounds extremely high unless you are averaging something like 10-15mpgs? (or leaving a trail of it down the road)
I'm guessing they only put one gallon in to get you back out of the refill notification zone and sent you on your way.
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old March 13th, 2015, 08:27   #3
^^^my opinion, as well. You'll never get an accurate rate of consumption unless YOU fill the tank yourself.
Now that you have it filled, "drive more, worry less", unless your car tells you otherwise!
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is online now   Reply With Quote
Old March 13th, 2015, 08:41   #4
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Your dealer probably didn't fill it all the way up last time.
Also, I'm of the opposite opinion on your idling practice... if I were an Uber driver with a TDI, I'd let it run instead of starting and stopping the engine constantly, but that's just me.
Trusted TDI Mechanics Map || TDIClub Chat
VeeDubTDI is online now   Reply With Quote
Old March 13th, 2015, 10:25   #5
I would question if the dealer filled it all the way up, or just dropped a .5-2.5 gallon jug in and called it a day.
As for usage, it is my understanding that low usage occurs if you are doing mainly light interstate/hwy driving. If you are doing a lot of stop and go with the livery work, that will increase usage significantly as you are putting more load on the engine. That said I though VW designed the 5 gallon capacity to go 10,000 miles, so the short usage was probably not on a full tank.
Additionally, you need to make sure you get some hwy trips in. If you do too much stop and go, the car may never complete a regen.
Sigforty is offline   Reply With Quote
Old March 13th, 2015, 11:57   #6
You can watch for "regens" if you purchase a ScanGauge II and program it with to monitor your exhaust temps. Just do not shut it off during a regen noted by a higher exhaust #2 temp than usual at idle. You can also tell right now if you shut it off and the engine fan continues to run after the shutdown...... that usually means that you interrupted the regen.
2012 Passat TDI SE (Awaiting 3/9/17 Buy-Back)
2015 Lincoln MKZ Hybrid
2005 Ford F250
2007 Arctic Fox 5th Wheel
BPofMD is offline   Reply With Quote
Old March 13th, 2015, 13:04   #7
Fuel Economy: See Fuelly link
Top the tank off and then report back, probably in 20K or so.
psd1 is offline   Reply With Quote
Old March 15th, 2015, 11:58   #8
Good stuff, thanks!
Old March 16th, 2015, 16:12   #9
IN VCDS...under engine 01/ goto advanced measurements, check off items 448 & 453
it'll show you how full is the tank....
Assuming you have a VCDS, and if you think she is beautiful, then you need to communicate with her...
for a long and lasting love....and VCDS will pay for itself in no time....
shak911 is offline   Reply With Quote
Oil consumed between oil changes...10-15k miles interval? Mawcus VW MKIV-A4 TDIs (VE and PD) 14 October 30th, 2013 04:17
Golf VI AdBlue tank location CDerekGo VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 November 30th, 2012 17:57
Anyone have confirmation on location of Adblue tank? Fixmy59bug VW Passat Family (NMS and B7) TDIs (2012+) 12 November 25th, 2012 07:05
AdBlue tank rattle? scott10s VW Touareg TDIs 4 May 7th, 2012 03:32
1st tank of fuel consumed by my 09, 40.29 MPG's Dan"Gerous" TDI 101 5 May 21st, 2009 20:50
Page generated in 0.13977 seconds with 11 queries
[Output: 92.34 Kb. compressed to 79.13 Kb. by saving 13.22 Kb. (14.31%)]
