IanFlo
This should be an easy one. But I see a couple components that may have failed and am not sure how to test.
I have a 2006 tdi pkg#1, no climatronic. I can feel heat when the fan is off, but when I turn the fan on the heat disipates. If you let it go for a moment, it returns but goes away again after the fan is turned on.
Any ideas? Is there a heater core, and aux. heating element? I have acsess to a snap on modus- will it detect a trouble code? Anything else I should check?
