For reasons that I will explain in more detail later..........
Well, it's later and I've got all the pictures resized so I figured I'd update this thread.
The thing that instigated all this was a clutch issue which is still lingering - details on that are in
this thread starting on post 27
I'll step back and try to go through this in a way that somewhat makes sense.
From above - the engine is out and on the stand due to the aforementioned clutch issue. This is what it looked like as it came out with the GTC1444VZ, SDI intake and external wastegate on the EGR port.
I dropped the engine out the bottom while the car was on the hoist. Never done it this way before and it worked out relatively well. Main thing was it saves some time assembling/disassembling the front clip and having to discharge/recharge the A/C system. Only minor issue was making sure I had a place for the A/C compressor to get tied up and that I forgot to drain the power steering reservoir so ended up with an oily mess on the floor.
Once the engine was on the stand, I rolled it over, pulled the oil pan and checked the rod and main bearings. As noted in earlier posts, the mains were fine, but the rods were "tired" again
While I waited for sputter coated rod bearings to arrive from Darkside, I installed the girdle that I've had for a couple years. The girdle went in relatively easy, but there were a couple small hiccups.
1) You need a 12mm 12pt deep socket for the ARP main studs. The Snap-On socket that I had has too small of a hole on the inside so I had to bore it out on the lathe with a carbide tool so it wold go over the threads of the stud.
2) A couple of the bolt holes were just ~0.010" off so 2 of the oil pan bolts wouldn't go in without dragging on the sides of the girdle. Not a big deal, just drill them out.
3) You have to add material to the back side of the oil pan (flywheel side) at the pan rail so you can machine out the inside so it clears the two rear most ARP main studs/nuts. I elected to TIG weld on the outside and then machine out the inside. The pan didn't weld too bad for being cast aluminum. I've heard of some epoxying or JB Weld after grinding away enough to clear on the inside. Sorry, apparently no pictures of the pan welding.
4) I had to grind my main cap spacers to specific heights so I could match the taper that's in my block. There was ~0.008" difference from front to rear. Not a girdle issue, but a block issue.
5) You end up losing the plastic windage pan with the girdle. I didn't know this ahead of time and ended up breaking mine trying to make it fit.
Hopefully with this, the sputter coated bearings and the smaller oil pump gear, the rod bearings live a bit longer and I don't window a block.
Mounting up the 2nd turbo seemed easiest outside of the car, however you lose the reference of where the rest of the car is when you do this (firewall, brake booster, transmission, etc). Fortunately I had access to another stock MKIV TDI so I pulled that into the shop and made a few reference measurements to the valve cover, firewall, shift linkage, brake booster etc and was able to avoid a few potential mishaps. It turned out that I wasn't going to be able to keep my SDI intake and this was the best location for the 2nd turbo. I just strapped it on for mock up. The intake clears the wastegate and brake booster, it clears the firewall, the exhaust will make it all the places it needs to go. Ok - next steps are to take this concept and make it a reality - in the next post.
