View Poll Results: What style mount are you running
Side mount 4 80.00%
Front mount 1 20.00%
Voters: 5. You may not vote on this poll
Old April 15th, 2014, 18:05   #1
geardriven
TDI(s): ahu
Default Motor Mounts
Ill start off by saying i know this has been documented by many, but noone ever give an explanation as to why they chose to do it that way. that is why I am starting this thread.
I would like to know why you chose the style mount you did, if you would change it if doing it in the future, the style/type mount you are using(or p/n s are great)
I am not looking for a thread that turns into an argument but debates are going to start without a doubt. nor am I looking solely for a best design. I am simply torn on how i want to do my mounts and this seems like a good way to help with my decision.
So what are you guys running,
traditional side mounts- proven, doesnt obstruct service of acc. components, slightly more work to make
front mount w/torque strut- also proven to work, easy to fabricate, takes away space in front of engine and obstructs service
The thing that worries me that is making me lean towoards side mounts is the added strain on the bellhousing/adapter area.
Yes I know, I have searched and I could probably tell you every mount used in a swap, but I have seen a couple people use the front mount setup and many using the side mounts. Is this solely because the last guy did that so you followed suite?
Enough of me talking, tell us your mount setup, why you chose it, how its working out and any clearance problems you may have ran into.
geardriven is offline   Reply With Quote
Old April 15th, 2014, 18:52   #2
Reddok
Reddok's Avatar
Fuel Economy: Jetta: 40.8 avg, 47.1 best. Jeep: 30 avg.
No option for 'both'? lol. I was running side mounts for the first two years, but in the last round of repairs, I added the front mount. The issue with running just side mounts is that they are down very low on the engine. This allows the top of the engine to shake around significantly. The front pendulous mount is mounted much higher on the engine and significantly reduced vibrations on my engine. I still need to run the side mounts as well as I have no way to fit the factory dogbone in the stock location.
2000 Jetta 01M: Ventectomy, Snowscreen removed, Injection timing advanced, EGR dialed back.
2002 Jeep Liberty TDI Project: 2002 ALH, 1749VA, NSG-370 6-spd, PP764's on T4's, 11mm pump, PD150 intake, custom tune, Cummins lift pump, 2.8 CRD intercooler, 2.5" DP/exhaust with Magnaflow cat and Walker Quietflow muffler.
Reddok is offline   Reply With Quote
Old April 15th, 2014, 19:57   #3
JaysinSpaceman
TDI(s): Golf
I'm running the side mounts on my yota project but I have a 1z motor so it doesn't have the provision for the front mount. The driver's side mount was a bit hard to design to get three bolts into the block, but it was doable. The driver's side also interfeared with the oil filter so I had to run a remote filter. I haven't really driven it (other then backing it in and out of the shop) but the vibrations seem reasonable with the Mercedes mounts that I am running. Time will tell.
Jaysin
JaysinSpaceman is offline   Reply With Quote
Old April 15th, 2014, 20:49   #4
geardriven
TDI(s): ahu
thank you this is the info I was hoping to collect! keep em coming
Old April 15th, 2014, 21:13   #5
cumminsfromthecold
cumminsfromthecold's Avatar
Fuel Economy: TDIYota 28-30, always on B20-B99.9, R32 terrible, blue B4 TBD
Pics of my 1997 1Z TDI mounts on the '84 Toyota begin on page 8 of my build thread, here:
http://forums.tdiclub.com/showthread.php?t=304345&page=8
I used early '90s BMW 325i mounts. I would not use them again. I would use hydraulic/oil-filled mounts like others, including jaysinspaceman. Vibrations at idle are too much, and while uncomfortable, I worry more about vibrating things loose on the truck over time.
The thick steel and gusseted design should stand the test of time. Combined with the new, lifetime-warrantied Trailgear tranny/crossmember mount, I feel confident when doing questionable things in 4WD .
'84 Toyota truck 1Z TDI build thread, Frankentuned.
Past - 1997 B4 (burgundy): 1999.5 Jetta TDI 5-spd: 2001 W8 sedan: 2001 Jetta wagon TDI 5-spd. Ongoing silliness - 2000 Passault4 Gambler rallye wagon.
cumminsfromthecold is offline   Reply With Quote
Old April 18th, 2014, 14:01   #6
Frankendiesel
On my 1Z in my Chrysler minivan, I used 1 VW mount and 2 Chrysler mounts. The VW mount is passenger side rear and is in the stock location. It seems to be doing its thing just fine. The front center mount is a Chrysler donut and even a brand new one stretched in a short amount of time such that it bottoms out and causes significant vibration at idle. The third is center mounted (pendulum) on the transmission. I used a Chrysler mount here and it seems to be working fine.
I am looking to redesign the front mount very soon - either I'm going to fabricate something out of better material, or redesign it altogether and put in a VW TDI mount.
Thanks for starting this thread - I've been meaning to inquire for a while now too!
1998 Chrysler Town & Country LXi with a TDI transplant from a '98 Jetta "Frankendiesel" 37mpg; mufflerectomy, 2.5" pipe cat-back, EGR delete, more to come...
2000 NB race pipe & Panzer plate.
1985 Mercedes 300SD on SVO since 2006 (Sold)
Frankendiesel is offline   Reply With Quote
Old April 26th, 2014, 11:44   #7
jimbote
jimbote's Avatar
2.0 ALH in a tacoma ... im utilizing the stock vw front mount modified with an extra two tabs for a total of five mounting points at the front of the block ... this stock mount is bolted solid to an "A" frame that mounts to the truck frame using dodge 318 rubber mounts (cheap and in stock ) and some 2" angle welded to the frame .... i chose this way of mounting due to the simplicity and the room it freed up on the sides of the motor ... vibes are very livable even though i'm running a BHW short block with balance shaft delete, and then really only noticeable at idle and when lugging ... overall I'm very happy with the setup
Better motor mounts? sardo_67 Upgrades (non TDI Engine related) 14 November 13th, 2013 10:33
Motor Mounts miner85 TDI 101 1 October 7th, 2007 17:07
motor mounts onjeffriv Upgrades (non TDI Engine related) 5 January 14th, 2006 20:57
Motor mounts EHB VW MKIV-A4 TDIs (VE and PD) 4 July 26th, 2004 19:18
New Motor Mounts Herm TDI VW MKIII-A3/B4 TDIs 10 May 7th, 2003 19:06
Page generated in 0.15337 seconds with 12 queries
[Output: 84.43 Kb. compressed to 73.68 Kb. by saving 10.76 Kb. (12.74%)]
