Old January 16th, 2004, 11:17   #1
speedR
Default Blower motor stopped working. No Heat!
Heya, I step into the car today and the windows are all frosted. I turn on the heat to (2) and crank the radio. 15 minutes later there is still frost on the windshield so I turn down the radio and have a listen. Just what I thought no heat is blowing. Nada!
So I'm left with no heat when it's -35 out. Any help? Thanks!
speedR is offline   Reply With Quote
Old January 16th, 2004, 11:40   #2
garnet
Fuel Economy: 50/46/40
This may seem very stupid but, I had that problem once.
In the passenger floor there is an inlet for air. My newspaper bag got stuck in it once and I had no heat either. Don't know if this helps but take a look down there and make sure nothing is stuck.
garnet is offline   Reply With Quote
Old January 16th, 2004, 11:59   #3
golfstream
Fuel Economy: 55, 49, 45
Could it be just a blown fuse?
Mel
golfstream is offline   Reply With Quote
Old January 16th, 2004, 12:03   #4
weedeater
Fuel Economy: 54/43/38
Try defrost or the highest speed setting. If it blows then, the problem is the resistor pack that controls the fan speed. If it still doesn't work, it's a fuse or fusable link.
weedeater is offline   Reply With Quote
Old January 16th, 2004, 12:21   #5
speedR
Just went to have a look at the fuses. Turn on the car to see if any othe fuses are out and the blower motor turns over when I turn on the ignition [img]/images/graemlins/rolleyes.gif[/img] . This car scares me some times [img]/images/graemlins/blush.gif[/img]
Old January 16th, 2004, 17:39   #6
sootwagen
sootwagen's Avatar
Fuel Economy: Who cares???
You didn't indicate what year or model you are working with, but one other spurce of problems could be your ignition switch...
sootwagen is offline   Reply With Quote
Old January 16th, 2004, 20:29   #7
PetethePilot
Fuel Economy: 64 imp 56 imp 49 imp
Same thing happened to me Speed on my Y2K. Drove me nuts. No blown fuses the fan would work sometimes and sometimes it wouldn't didn't matter the speed. I hooked up a test lite to the blower motor to see if it was the relay or the fan motor and waited until it guit again. A couple of weeks later it did it again and the lite confirmed my fear,it was the blower motor.
Question does your fan howl in cold weather? If so when your fan motor quits again remove the hepa filter, this will let you peer down at the blower squirrel cage. Take a stick and try and move it. Sometimes this will get it going. The problem is the housing around the fan fits so tight in the cold weather it shrinks enough to cause tip rub (howling) or worse the fan won't turn. In the end I paid for a new blower assembly which really pissed me off cause there not cheap!
Good luck
Pete
PetethePilot is offline   Reply With Quote
Old January 19th, 2004, 08:38   #8
ACHTUNG TDI
Does the blower fan work at any of the speed settings? I'm not sure about VWs but fan speed is regulated on other cars by a blower motor resistor. If resistor is bad fan will work but only at high speed.
ACHTUNG TDI is offline   Reply With Quote
Old January 19th, 2004, 13:40   #9
pghPAtdi
pghPAtdi's Avatar
Fuel Economy: 57/40/34
[ QUOTE ]
[/ QUOTE ]
I would like to know that too. Mine does it on 1, 2 and sometimes setting 3 and it doesn't go away when it's really cold out even when the engine is warmed up. Just thinking it's maybe a impending breakdown of my HVAC fan. dealer always says "nope didn't hear a thing" [img]/images/graemlins/tongue.gif[/img]
Tks
Dave
pghPAtdi is offline   Reply With Quote
Old January 19th, 2004, 17:29   #10
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Another known issue is the squealing they sometimes make. There is a TSB on the blower motor. Don't know how VW is handling it though.
jasonTDI is offline   Reply With Quote
Old January 20th, 2004, 06:22   #11
TEJ823
TEJ823's Avatar
Fuel Economy: 58/50/45
I had problem with intermitant fan and changed the resistor pack, twice (actually the thermal fuse in the pack) and the blower motor, but found the problem was in the speed control rotary switch. Was fiddleing around (on-off-on-off, push wiggle etc.) and the fan finally stopped working at all speeds and blew the main blower fuse. I still have the old switch panel and plan to tear it down when the garage warms up a bit.
TEJ823 is offline   Reply With Quote
Page generated in 0.08587 seconds with 10 queries
[Output: 94.26 Kb. compressed to 79.22 Kb. by saving 15.04 Kb. (15.96%)]
