Old February 18th, 2015, 11:22   #1
Frans
TDI(s): Golf MK2 TDI
Default Dutch Auto Parts, gearbox sets, engines, turbos, injection pumps
Dutch Auto Parts is specialized in TDI parts. We sell quality used, rebuild, and new TDI parts.
Auto to manual kits, injection pumps, standard and custom turbos, engines, engine swaps, engine parts, gearboxes, euro headlights etc
We have been on the forum for several years now, it’s time to finally open up a vendor thread.
We are located in the Netherlands, Europe and have daily shipments to North America.
Our webshop will be online somewhere around march/april which makes ordering even easier.
For more information or to order sent us a pm or an email to info@dutchautoparts.com
All prices are in USD and INCLUDING economy shipment(4-5 business days) to the US and Canada
Payment via paypal (4.6% fees) or wire transfer.
Auto to manual conversion sets:
-Auto to 5 speed set mk4
This is the basic set and comes without a flywheel/clutch assembly. $975 including shipment. A good used DMF+ clutch is an additional $125.
-Auto to 6 speed set mk4
Special: $1500 shipped with new sachs pd150 flywheel/clutch set.
-5 speed to 6 speed mk4
$1450 shipped with new sachs pd150 flywheel/clutch set
-Auto to 5 speed set Passat BHW
The basic set comes without a flywheel/clutch and outer cv joints. It’s possible to swap the outer cv joints from the auto axles.
The basic kit comes with a regular TDI box. DHF/EEN/DHL .
The longest ratio 5 speed available is the FHN/GGB. The 2nd “longest” is the DUK.
Price of the basic set is $1200US including shipment
Options to the basic set:
FHN transmission + $185
DUK transmission + $100
Valeo 1.9TDI SMF + $490
Starter interlock switch, connector and wires + $49
2x new quality outer cv joints + $125
- Auto to 6 speed swap passat BHW
The 6 speeds have known issues with diff and pignon bearings. That’s why we only sell rebuild ones with internal upgrades.
Price for a full 6 speed (DQS even longer than 5 speed FHN) swap set is $2750. This is with new DMF and sachs clutch.
Picture coming soon.
-5 to 6 speed set Golf MK5.
Only the longest 6th gear ratio TDI gearboxes are used.
$1550 including shipment.
Gearboxes used:
02a TDI gearbox used, CTN, ASD etc $315 shipped
02J TDI gearbox used DQY, EGR,EGS etc $465 shipped
02M TDI gearbox 6 speed used $725 shipped
012 passat TDI 5 speed FHN $650 shipped
012 passat TDI 5 speed DUK $540 shipped
012 passat TDI 5 speed EEN, DHL, DHF etc, $490 shipped
Injection pumps:
We offer used, checked and resealed pumps, but also quality rebuilds.(Oem bosch parts). Pumps are build in our own facility. We offer 10, 11mm and 12mm pumps.
We don’t require the old core pump!
AHU 10mm checked,tested,resealed $355
ALH 10mm checked, tested, resealed $395
AHU 10mm rebuild $650
AHU rebuild + converted to 11mm $825
ALH 10mm rebuild $685
ALH 11mm rebuild $850
Rebuild injectors:
All injectors are balanced. All nozzles are made in Italy. Core charge is $125
Injectors 90hp $295
Injectors 110hp $345
Injectors with bosio 502 $390
Injectors with bosio pp764 $400
Injectors with bosio r520 $475
Frans is offline   Reply With Quote
Old February 18th, 2015, 11:25   #2
Frans
Engines
We offer good used and tested engines. Please see long blocks below. Contact us for complete engine swaps or spare engine parts
AHU engine block + head used, no attachments $650 shipped
ALH engine block + head used, no attachments $775 shipped
AJM/BEW engine block + head+ injectors used, no attachments $925 shipped
ASZ/ARL engine block + head +injectors used, no attachments $1250 shipped
AVF/AWX, 1.9 TDI PD to replace the troublesome BHW 2.0 TDI, engine block + head +injectors used, no attachments $1055 shipped
Engine heads
We offer good used and rebuild heads.
-1z used, comes with camshaft and lifters $275
-1z rebuild with new INA lifters and camshaft $575
-ALH used, comes with camshaft and lifters $345
-ALH rebuild with new INA lifters and camshaft $675
-PD head used $395 ex camshaft/bearings. Good used oem camshaft $120 Injector rocker shaft $100 each
-PD head rebuild $650 ex camshaft/bearings. Good used oem camshaft $120 Injector rocker shaft $100 each
Old February 18th, 2015, 11:25   #3
Frans
Turbochargers
We offer used and quality (re) build turbochargers. We only use the highest quality turbo parts available. All our turbos come with new internals! Every (re)build turbo comes with an upgraded 360 degree thrust bearing. All turbos are balanced on our own state of the art VSR balancing machine.
1 year warranty on rebuild turbos.
All used turbos are disassembled, checked and the vnt is cleaned!
Mk3
-1z/ahu turbo used passat b4 $200
-1z/ahu turbo rebuild $350
-AFN turbo , often used for vnt conversion on ahu/1z. $240
-AFN turbo rebuild $450
-AFN Manifold $110
MK4
-ALH vnt15 used $275
-ALH vnt15 rebuild $450
-Vnt17/gt1749vb rebuild $575
-Modified gt1749vb with oem vnt15 style compressor housing. Same performance!(no need to buy expensive turbo hose) $575
-VNT17/22 new (re)build $975
- DAP 18/56 turbo for ALH application, uses standard manifold with machined turbine housing and upgraded compressor +-240hp $1250
B5.5 Turbos
- BHW turbo rebuild $525
-BHW dap 1 (modified oem housings +-200hp) $675
- BHW dap 2 +-220hp , modified exhaust housing + larger turbine/ compressor $975
-BHW dap 3, 18/56, 240 hp. $1250
-BV43 $625
MK5
BLS/BRM
-PD140 turbocharger rebuild $575
PD140 turbocharger dap 1 , (re) build modified for 200hp (With PD150 injectors) $775
Old February 18th, 2015, 11:25   #4
Frans
Parts clearance:
Tubular manifold for the GTB series turbo, new. Only one available $450 shipped.
Old February 18th, 2015, 11:26   #5
Frans
reserved 4
Old February 18th, 2015, 19:03   #6
boertje
boertje's Avatar
Looks good Frans. Mooi. Can you include the wire pig tail for the cruise control switch on the clutch pedal? Do they use a starter safety switch on the clutch pedal in Europe?
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is offline   Reply With Quote
Old February 18th, 2015, 20:59   #7
Caddy 16v
Caddy 16v's Avatar
Got my 17/22 from Frans some months ago, everything went smooth, great performing turbo!
2000 Jetta, mufflerectomy, Evolution Atlas skid plate, OEM xenon reps retrofitted, Hella Micro DE, HFLOX Warp 3 nozzles, 3 bar map, Malone Stage 5 Custom, Euro 17/22, DC Stage 4 clutch, STAGG suspension, Curt hitch, Auber EGT and NSP boost gauge, Hella Sharptones, Rally Armor mud flaps, 1.8T pancake pipe, upgraded SMIC, VAG-COM, all offroaded out
2000 Golf, JSP Armadillo skid plate, limo tint (Sold)
Caddy 16v is offline   Reply With Quote
Old February 19th, 2015, 03:51   #8
k_harley
k_harley's Avatar
Good stuff, Ive bought many engines, transmissions, swap packages, turbos, injection pumps, etc. from Dutch over the past few years and he always delivers a good product on time.
www.kmhmotors.com
Specialized VW / Audi Service, Sales, & TDI Conversions
MALONE DEALER
k_harley is offline   Reply With Quote
Old February 22nd, 2015, 21:18   #9
A2VR6
I order a gearbox and a clutch kit from him for my B5.5 TDI and I am looking forward to it.
A2VR6 is offline   Reply With Quote
Old February 23rd, 2015, 05:26   #10
50harleyrider
Great Frans, I'm still looking for a diesel conversion for my F-150.
50harleyrider is offline   Reply With Quote
Old February 25th, 2015, 19:06   #11
secret ingredient
Fuel Economy: 48-51, depends on my mood
Just received my transmission today. Very pleased with the entire transaction, which was quite easy and pleasant.
secret ingredient is offline   Reply With Quote
Old February 27th, 2015, 04:33   #12
mrrhtuner
mrrhtuner's Avatar
I really like your prices Frans...much better then other dealers.
I will be saving up for the B5.5 auto-to-manual swap :-)
mrrhtuner is offline   Reply With Quote
Old February 28th, 2015, 07:57   #13
tdidieselbobny
tdidieselbobny's Avatar
These prices are VERY reasonable-especially if it includes shipping. I will have to remember this thread if I decide to get another head for the B4.
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten-'15 Silk Blue Golf Sportwagen w/DSG, 23k miles....'16 Kubota BX1870 MMM/FEL, 100hrs!And now an '03 Jetta TDI 5spd w/ 420k,RC2,Sprint 520's,Dieselgeek short shifter and oil bypass, and a few other goodies....
tdidieselbobny is offline   Reply With Quote
Old March 4th, 2015, 10:41   #14
Frans
Wire pigtails are included for the clutch pedal and neutral connector. There is no starterinterlock switch on the mk4 here in europe. It can be included with a new "long" pedal. $40
Email sent
We try to keep prices reasonable. Due to the high volume we can offer very fair shipping rates.
Old March 9th, 2015, 12:42   #15
db747
db747's Avatar
Fuel Economy: 28-32 mpg.
Whats the bv43 b5.5 turbo hp rating? and do you recommend the modified garret housing over the bv43?
db747 is offline   Reply With Quote
Dutch Auto Parts 52172 TDI Power Enhancements 39 January 22nd, 2014 19:53
Which 90bhp engines came with variable vane turbos? bhodgkiss TDI Power Enhancements 13 March 28th, 2012 10:49
1Z / ALH blocks, turbos, pumps, trannys, ... rjr311 Private TDI Items for Sale/Wanted 12 April 6th, 2010 06:37
How often do turbos destroy engines? sisyphus TDI 101 18 February 20th, 2009 17:19
WTB: injection pumps, turbos KERMA Vendor & GroupBuy items for sale 1 December 24th, 2005 15:45
Page generated in 0.17828 seconds with 11 queries
[Output: 136.80 Kb. compressed to 115.14 Kb. by saving 21.67 Kb. (15.84%)]
