Old July 4th, 2012, 14:52   #1
Bud44
Bud44's Avatar
TDI(s): 03 Jetta TDI
Unhappy Suspension banging noise coming from left-rear, only happens making left turn ???
Banging sound coming from the left rear of my 03 Jetta TDI. I can only hear it when I make a left turn, when I turn right I don't hear anything...
I replaced the shocks a month ago so it's not that. Also just replaced (yesterday) the rear axle bushings and it's not that. (that was a P.I.T.A)
I removed everything from the trunk including the spare tire. Also, the amp mounted in trunk is not loose.
I looked at the exhaust and muffler and wiggled it and its not banging on anything either ...
I am perplexed
HELP
http://youkits.freeforums.org/
Bud44 is offline   Reply With Quote
Old July 5th, 2012, 14:00   #2
vwdieseling
vwdieseling's Avatar
Fuel Economy: 37 MPG
Did you check rear shock bushings, also your spring perches to see if springs possibly rotated out of there perches. I have a 2000 Beetle, but I believe the rear suspension is different from the Jetta's. I have just a shock and a separate spring. I believe the Jetta's have a strut type. If not it could be your shock mounts. I replaced my rear shocks two weeks ago. I thought I would go cheap and just do the shocks. Talk about some crazy banging. My shock mounts needed replaced, it is recommended when replacing shocks or even struts to replace bushings and mounts depending on what you have.
vwdieseling is offline   Reply With Quote
Old July 5th, 2012, 14:07   #3
Bud44
Bud44's Avatar
Thanks, I will check shocks again. maybe I got a defective one.
Old July 7th, 2012, 09:51   #4
Bud44
Bud44's Avatar
Ok well, i removed the left rear shock and took the car for a drive and I did not hear any banging noise so I guess I had a defective shock. I found my sales recipt and i was still within the 90 days warranty. So I exchanged the shock put the new one on and the car drives fine, no noise. All this time it was a defect in the shock...
Old July 14th, 2012, 22:00   #5
que4dog
que4dog's Avatar
Interesting, I purchased new shocks and mounts and I seem to have the exact same problem. I'll try to remove the shock to check it.
que4dog is offline   Reply With Quote
Old July 14th, 2012, 22:10   #6
Bud44
Bud44's Avatar
My banging is back. Ha. Maybe its just the cheepo monroe shocks for $29 from pep boys.
Old July 15th, 2012, 20:04   #7
magnusdog
Location: Just outside the Berkeley of the Midwest (Madison, WI)
When you put in the new shocks the first time, did you also replace the shock mounts at the top? I've read that they can wear out and cause a clunk. It's at least another place to check out or rule out.
Good luck- chasing down odd noises that of course only occur while in motion has got to be one of the most frustrating things to do with cars.
Brad
Why yes, I am an Infidel- says so right there on my license plate...
magnusdog is offline   Reply With Quote
Old July 15th, 2012, 21:16   #8
Bud44
Bud44's Avatar
Brad
I did not replace the shock mounts. I will look at it. Thanks.
Old August 24th, 2012, 15:23   #9
Bud44
Bud44's Avatar
Well the banging is still there, coming from the left rear. The shock mounts look tight.
Squeaky problem in Front left suspension and may be left rear suspension VWINDIA VW MKV-A5 Golf/Jettas 10 May 31st, 2015 18:13
Suspension Banging Noise BuffaloDiesel VW MKIV-A4 TDIs (VE and PD) 15 June 27th, 2012 07:15
Left Hand Turn Noise at Right Front oEo TDI 101 8 March 30th, 2007 05:59
Front Left Suspension sharp clanking noise Schwrtz27 VW MKIV-A4 TDIs (VE and PD) 1 July 27th, 2006 00:49
Grinding noise from the left rear CochiseTDI VW MKIV-A4 TDIs (VE and PD) 0 June 28th, 2004 12:35
Page generated in 0.17428 seconds with 11 queries
[Output: 93.55 Kb. compressed to 79.96 Kb. by saving 13.59 Kb. (14.52%)]
