Old March 25th, 2012, 07:26   #1
bhodgkiss
Default Which 90bhp engines came with variable vane turbos?
As above, does anyone have the engine codes please?
Some of the later late 90's early 2000's cars?
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old March 25th, 2012, 08:01   #2
K.I.T.T.
K.I.T.T.'s Avatar
TDI(s): N/A
1.9l VE ALH, AHH.
And since you've not specifically implied this 90ps engine has to be a 1.9l...
1.4l R3 PD ATL
1.6l R4 CR CAYB
Ash
PD injector differences (click)
K.I.T.T. is offline   Reply With Quote
Old March 25th, 2012, 15:35   #3
bhodgkiss
Thanks ash
Did the mk3 facelift ibiza ever have the alh engine?
That's what I'm after. Otherwise the 110bhp asv which i know are available in the UK
Old March 25th, 2012, 15:49   #4
Olit
Hi!
Not according to Wiki.
1,9 TDI - PD, 74 kw (101 PS; 99 bhp) @ 4,000 rpm; 240 newton metres (177 lbf·ft) @ 1,800–2,400 rpm — ATD, AXR, BEW, BMT
SEAT Ibiza Mk3 (ATD: 09/01->, AXR: 05/05-11/09, BMT: 09/06-11/09)
Olit
Olit is offline   Reply With Quote
Old March 25th, 2012, 16:02   #5
K.I.T.T.
K.I.T.T.'s Avatar
TDI(s): N/A
I think he meant Mk2f Ibiza
SEAT Ibiza Mk2 (1Z: 07/96-12/96, AHU: 12/96-06/99, AFN: 03/97-06/99, ASV: 03/99-05/02, AGR: 04/99-05/02, ALH: 10/99-05/02)
Whether they came in the UK with that engine is another matter entirely. Does it matter whether it's an AGR/AHU? If you're going to toy with it, it's not exactly hard to swap from WG to VNT.
Ash
Old March 25th, 2012, 16:23   #6
Olit
I sort of suspected that - but you never know... Well - asked and aswered!
Olit
Old March 26th, 2012, 06:06   #7
bhodgkiss
yes sorry the mk2 facelift (which most people on the seat cupra forums call mk3?)
yes a wastegate turbo version isn;t an issue, but as the ASV was definitely available, I thought the ALH might also be, and be cheap and easier to mod.
So are there any differences at all between ALH, AGR, AHU, AFN, ASV in terms of bottom end? Or cylinder head, so valves, cam lift....
Didn't the ASV have better oil cooled pistons for example?
Which have the strongest rods?
Bascially, which is strongest for modding to 200bhp?
Old March 27th, 2012, 00:41   #8
bhodgkiss
And........would a pd bottom end bolt up to a VE head, or do the water jacket holes etc etc not line up?
Old March 27th, 2012, 13:09   #9
bhodgkiss
can the asv engine be remapped through the OBD port please?
is it the later style ECU?
Old March 28th, 2012, 09:36   #10
m1ketdi
TDI(s): Leon BKD
Fuel Economy: 50+mpg
Nope...
m1ketdi is offline   Reply With Quote
Old March 28th, 2012, 09:53   #11
wersuss
wersuss's Avatar
TDI(s): 1.9 TDI
Fuel Economy: 5L/100km
Can 1z engine be remaped with port 16 pin?
wersuss is offline   Reply With Quote
Old March 28th, 2012, 11:13   #12
bhodgkiss
Nope to which question mike? I've asked a few
Old March 28th, 2012, 11:40   #13
Rub87
Originally Posted by m1ketdi View Post
Nope...
Depends, after 2001 they have edc15vm+, which can be done through obd.. ibiza 6k2 is offcourse always soldering
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old March 28th, 2012, 11:49   #14
m1ketdi
TDI(s): Leon BKD
Ok thanks for that info, I thought all of the UK ones at least were a soldering job....
Variable-Vane Turbo? whitelite777 TDI 101 6 November 10th, 2004 15:46
VAG Variable Vane Turbochargers Chris220SDi TDI Power Enhancements 3 April 27th, 2004 11:27
Variable Vane control question... wwhalenc TDI 101 5 November 17th, 2002 19:33
Newbie Question: Variable-vane turbo upgrade? MJSfoto1956 TDI Power Enhancements 0 March 21st, 1999 09:03
Page generated in 0.15056 seconds with 11 queries
[Output: 116.79 Kb. compressed to 97.10 Kb. by saving 19.69 Kb. (16.86%)]
