Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old February 18th, 2010, 10:58   #1
MD06JettaTDI
TDI(s): 06 Jetta
Default 2006 Jetta driver window/mirror only stopped working
On my 4 door Jetta TDI, my driver window and driver door mirror stopped working. All other windows work fine. I replaced the window motor and regulator (with 2 seperate ones) thinking that I had a bad one, and it still did not work. SO I took a new switch assembly out of another 06 Jetta thinking that it must be the switch. Still did not fix it. Does anyone know if there is a fuse or something that operates just the driver window and mirror?
Thank you in advance for any advice.
MD06JettaTDI is offline   Reply With Quote
Page generated in 0.10958 seconds with 10 queries
[Output: 42.41 Kb. compressed to 39.80 Kb. by saving 2.60 Kb. (6.14%)]
