Old February 19th, 2009, 13:07   #1
sisyphus
sisyphus's Avatar
Default How often do turbos destroy engines?
Why does it seem like every so often we see a thread about someone driving along minding their own business and all of a sudden the engine runs away and the poor guy now has a scrap car? Is this unique to VW's? Is this what we all have to look forward to?
sisyphus is offline   Reply With Quote
Old February 19th, 2009, 13:21   #2
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
it's not unique to VW's.. it can and does happen with any turbodiesel..
If you get the engine shut down before it revs to 7k or runs out of oil, it's usually fine..
Both of my tdis did it within 48 hours of each other.. Go figure.. one had 221k on the factory turbo and it was chipped since 140k... the other I haven't put a turbo on yet but the engine survived..
A bad engine is no reason to scrap a car.... Unless it's a $500 car to start with..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old February 19th, 2009, 13:23   #3
dieseldorf
top post dawg
dieseldorf's Avatar
...or it's fitted with an 01M
Old February 19th, 2009, 13:25   #4
TDIJetta99
TDIJetta99's Avatar
I have AlanTDI's wagon here with a hole in the block and a BRAND NEW 01M that was installed recently..
Old February 19th, 2009, 13:34   #5
joetdi
How much do you want for that AG4 transmission?
joetdi is offline   Reply With Quote
Old February 19th, 2009, 13:37   #6
dieseldorf
top post dawg
dieseldorf's Avatar
Alan's gonna be a sad fellow tonight
Old February 19th, 2009, 13:54   #7
TDIJetta99
TDIJetta99's Avatar
umm... trans isn't for sale.. I'm looking for an engine to fix the car..
Alan already knows the damage..
Old February 19th, 2009, 14:41   #8
FL2AK-tdi
FL2AK-tdi's Avatar
Fuel Economy: best: 49.91 hwy w/ ULSD worst: 28.xx city with Jet-A/D1 mix
It's probably a LOT more common on Detroits than VW's. wasn't there a thread here a while back discussing how to stop a runaway?
Originally Posted by butter nuts
I'm used to reliable cars that rarely break (Toyotas) so owning a VW will be a new territory for me.
Originally Posted by JASONP
...you [are] a loyal VW owner, wether you like it or not
Originally Posted by NB_TDi
I'm just not buying the whole, 01M sucks...end of story bit.
2001 Jetta Sedan GLS. 01M trans. Koni Reds. Evo Skidplate. Otherwise stock.
I <3 my automatic transmission. =)
They say that if you play a Windows CD backwards, it plays satanic music; that's nothing, if you play it forward, it installs Windows!
FL2AK-tdi is offline   Reply With Quote
Old February 19th, 2009, 15:12   #9
TDIJetta99
TDIJetta99's Avatar
it's tough with an auto, even with a functioning ASV... 5-speeds are easy, 5th gear, let go of clutch, stand on brakes..
Old February 19th, 2009, 15:21   #10
whitedog
Detroits just SOUND like they are running away.
Can fold paper in half eight times.
Old February 20th, 2009, 04:38   #11
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
It's not the turbochargers. Naturally aspirated diesels can also suffer "run-away" as worn rings or bad valve guides let crankcase oil be a "fuel" as the lubricating oil gets ingested into the combustion chamber. It would be just as correct to ask "Why do engines destroy turbos?"
Svante Arrhenius 1896
Old February 20th, 2009, 06:19   #12
TDIJetta99
TDIJetta99's Avatar
while a runaway in an NA diesel is possible and does happen, it's not as sudden and abrupt as a turbocharger failure in a TD.. An NA diesel that runs away has had low compression for a LONG time and has probably given symptoms of such for a while, like hard starts, excessive smoke, oil consumption, etc..
We all know a TDI that runs away will be running perfectly, then suddenly BANG! off we go... no warning, nothing.. just smoke, and rpm's..
Old February 20th, 2009, 09:54   #13
Dodoma
One way to avoid turbo failure is idle the car for some seconds before shutting off. Turbo spins at very high revolutions and if shut down abruptly (without idlying or slowing), oil flow is intruppted. Without oil that cools and lubricate moving parts, the turbo remain hot, and heat warps metals, and thereby bringing their demise. The same rule applies when you start to move. After starting, idle for few seconds and then pull of gently to the freeway speed. You do not have to put stress on turbo by flooring the pedal. Flooring effect is same as that of an impulse. The key rule is "keep gentle". However, if you are cruzing at 70 mph and hear weired noises, slow down, idle the car, open, hood or bonnet, investigate the noise area, and then shut down. There will be turbo failures when they are exposed to high temperatures, vibrations, and foot stress of the driver. Also it is prudent to clean the turbo vanes periodically. There is instruction for this on this forum somewhere. If you wish to emove the turbo problem forever, all you need to do is remove the turbo and seal to cavatues, making sure that there is passage for the exhaust to reach tail pipe. You will now have a not-turbo diesel that will be a little sluggist than before, pick-up time for 0-60 mph increased from 8 sec to 12-14sec.
Dodoma is offline   Reply With Quote
Old February 20th, 2009, 10:17   #14
Powder Hound
Powder Hound's Avatar
Turbochargers on these engines rarely (if ever) fail from heat stress. The EGTs experienced by a diesel are anywhere from 500-1000*F lower than from a similar gasoline fired engine.
Add to that using a good quality synthetic oil, and you just don't find a good reason to blame problems on heat.
You will notice that water cooling passages are not found on the turbochargers on these cars. A water cooled body is available, why would it not be included if needed? VW has never been shy on adding excess plumbing either... hmmm... must be because... it is not necessary.
Oh, and unlike prime time Japanese TV commercials, double posting isn't really necessary, Dodoma.
Old February 20th, 2009, 10:49   #15
TDIJetta99
TDIJetta99's Avatar
Hahahaha.. I actually drove my other tdi with the turbo removed and an 8v gasser exhaust manifold temporarily in its place. I needed to get it home and had no other way at the time. The car would barely even get itself up to 55mph, let alone accelerate with any authority..
I can't complain.. My factory turbo lasted 221k with me beating the crap out of the car since 120k.. chipped, injectored, and towing other cars since 140k..
Page generated in 0.16453 seconds with 10 queries
[Output: 127.91 Kb. compressed to 106.01 Kb. by saving 21.89 Kb. (17.12%)]
