Old November 21st, 2008, 21:22   #1
Deevo_3000
Deevo_3000's Avatar
Fuel Economy: 35 / 50
Default Air blower stopped working
Good time for this to stop working, of course as soon as it gets cold! No heat and No defrost sure is to drive with...
The fuse is good (#25 - 25A), maybe the fan motor just gave out? Any ideas?
2000 Jetta - VNT-17/22 - PP520 - Sachs VR6/G60
KermaTDI, IDParts
Deevo_3000 is offline   Reply With Quote
Old November 22nd, 2008, 01:05   #2
afarfalla
afarfalla's Avatar
pull out glove box, motor connector should be visible, put 12 volts to it, see if it runs
afarfalla is offline   Reply With Quote
Old November 23rd, 2008, 04:39   #3
2004STARWARSTDI
2004STARWARSTDI's Avatar
Default Blower
Guessing you checked it on all speeds? Could be a bad resistor pack.
Central Florida TDI Group
Ross-Tech VagCom/VCDS 1997-2014
A4 Limp Mode,A4 fan troubleshooting
Glow plugs 101 Ver. 2.0
Engine CEL Code Lookup. Turbo Hose To Egr Fix - TDIClub Forums
2004STARWARSTDI is offline   Reply With Quote
Old November 23rd, 2008, 08:50   #4
Deevo_3000
Deevo_3000's Avatar
Yes, it doesn't run on any speed. I'm going to take it out today. I'll probably be stuck with the dealer if I need to replace any of this right?
KermaTDI, IDParts
Old November 23rd, 2008, 17:30   #5
Franko6
I'd make sure it's not the fan. Sometimes they get gummed up and quit, especially right about NOW... winter isn't good on the fans.
I usually have them in stock. I can have one by Tuesday if you like. $85 if it's the fan and $80 if it's the fan resistor pack.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old November 25th, 2008, 22:24   #6
merkerguitars
TDI(s): 01 Jetta
Fuel Economy: 46ish
Pretty easy to replace the resistor pack/motor
For the resistor pack its underneath the glove box/ nothing to bad to remove just a piece of grey foam that is in the way.
Blower motor = ripping out the glove box which = ripping out the center console to get to the 1 hidden glove box screw.
Your Twin Cities area TDI mechanic, can do all sorts of work with over 5 years of experience, just PM if you need service. I work at Midwest Motorworks, just give me a call at 715-381-1100 I'll be more than happy to cure your TDI Woes
merkerguitars is offline   Reply With Quote
Old December 9th, 2008, 23:24   #7
Deevo_3000
Deevo_3000's Avatar
Hey thanks for the reply, i've been out of the country the last couple weeks so i didn't get to it until today. I don't know why they hid that one screw under the center console, kind of a PITA, whatever. Anyways, should I be able to pull just the motor part out? The thing doesn't seem to want to budge.
KermaTDI, IDParts
Page generated in 0.14211 seconds with 10 queries
[Output: 77.68 Kb. compressed to 66.84 Kb. by saving 10.84 Kb. (13.95%)]
