Go Back   TDIClub Forums > FAQs (Frequently Asked Questions) > TDI Power Enhancements
TDI Power Enhancements Archives on TDI Power Enhancement related items.
Old March 29th, 2009, 14:29   #421
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
That's awesome Fenwick.
74 MPH at 4000 RPM, that's 3rd gear.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old March 29th, 2009, 14:35   #422
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Old March 29th, 2009, 14:58   #423
fenwick458
fenwick458's Avatar
yep thats 3rd gear
fenwick458 is offline   Reply With Quote
Old March 29th, 2009, 15:05   #424
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Originally Posted by fenwick458
yep thats 3rd gear
Why 3rd and not 4th? You might see higher numbers with 4th, no?
Old March 29th, 2009, 15:40   #425
mojogoes
Or less!!
Old March 29th, 2009, 15:50   #426
That's what I was thinking.
2002 Jetta wagon, 358K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 255K; 2011 335d, 55K; 2015 Golf Sportwagen, 5K. Principal, http://www.idparts.com
Old March 29th, 2009, 20:36   #427
johnnloki
johnnloki's Avatar
TDI(s): 04 Golf TDI
Fuel Economy: 1100 km tanks, generally
You'll see higher numbers in third than fourth. You're putting down a multiplied torque number in first, second and third, almost even in fourth, and a division of your torque in fifth.
If the HP# comes from your torque #, then a lower gear will give you an overly optimistic view of both.
That's why first gear becomes near unusable once you really start tuning- Too much torque, multiplied by too much.
johnnloki is offline   Reply With Quote
Old March 29th, 2009, 21:38   #428
J double R
Fail Train Conductor
J double R's Avatar
Fuel Economy: 45-50 mpg
ain't that the truth... !
Originally Posted by meganuke
Trogdor! Burninating the TDI, burninating the peasants...
J double R is offline   Reply With Quote
Old March 29th, 2009, 22:01   #429
johnnloki
johnnloki's Avatar
TDI(s): 04 Golf TDI
http://forums.vwvortex.com/zerothread?id=4291312 (@ $800- see here) http://forums.tdiclub.com/showthread.php?t=243298
http://www.boraparts.com/catalog/pro...roducts_id=121
15 different flavors of win.
Old April 1st, 2009, 18:53   #430
Jon Linn
Ok, this may be a stupid question, but oh well. Where do I go to have a dyno performed on my car? I would like to join the dyno club.
1997 Jetta: sold
2002 NB (my car): 160,000 miles - AltiMAX HP's, Koni S.T.R.E.T. with 2" lift and TDITuning chip.
2002 Passat 1.8t Wagon (Wifes): 125,000 miles AltiMax RT's
Jon Linn is offline   Reply With Quote
Old April 2nd, 2009, 07:09   #431
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
HP comes as a product (multiplication) of torque and rpm.
Double the torque at the wheel by a lower gear and the wheel rotation speed is cut in half. 1 x 1 is equal to 2 x .5, so power doesn't change. Go up a gear, reducing torque, but the wheel rpm increases by a compensating amount. 1 x 1 is equal to .75 x 1.33, so power still doesn't change.
The difference between a lower gear pull and a higher gear pull is the amount of time needed to run from low rpm to red-line. A higher gear will take more time and reduce the effect of the turbo lag. If it takes .5 seconds for the turbo to spool up and your engine rpm rises too fast, you'll be past the natural peak before the full boost has built.
But... take too long, as might happen in a higher gear ratio, and heat soak becomes an issue.
I've done back to back 3rd, 4th, 3rd pulls and the power (wheel torque factored with wheel speed) is within fractions of a percent regardless.
Svante Arrhenius 1896
Old April 2nd, 2009, 10:22   #432
johnnloki
johnnloki's Avatar
TDI(s): 04 Golf TDI
I suppose it depends on whether your dyno is determining the RPMs based upon engine RPMs or wheel rpms. You could definitely be right, however, especially when you factor in how many shops have trouble getting an accurate RPM reading off the engine.
Attempt #17 at PMing Jeff underway now.
Old April 2nd, 2009, 10:52   #433
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
It still doesn't matter. Power is power.
Old April 6th, 2009, 08:16   #434
Leo__
Fuel Economy: 9 L/100km - if I'm lucky
Audi A6, 1997, 2.5 TDI (5cyl), AAT 85 Kw - stock
Chip, Nozzles, Turbo (+other small stuff):
Leo__ is offline   Reply With Quote
Old April 7th, 2009, 13:58   #435
btcost
btcost's Avatar
Fuel Economy: using Fuelly. . 33ish for now
This is old. from New England Dyno day last October. but I finally learned how to post pics. . so here you go
I need to dyno again, because now I have an 11mm pump installed.
2012 JSW platinum grey, Euro mirrors, euro switch, front & rear fogs, DG Panzer plate, euro hitch, towing springs & Parktronic (not finished yet)
1987 300DT: Blistein HD's, 16" CLK wheels, euro headlights w/levelers
URL=http://www.fuelly.com/driver/Btcost/jetta][/URL]
btcost is offline   Reply With Quote
Page generated in 0.17240 seconds with 10 queries
[Output: 127.42 Kb. compressed to 105.75 Kb. by saving 21.67 Kb. (17.00%)]
