Go Back   TDIClub Forums > FAQs (Frequently Asked Questions) > TDI Power Enhancements
TDI Power Enhancements Archives on TDI Power Enhancement related items.
Old December 30th, 2008, 19:00   #406
Scott02
TDI(s): Too Many
Fuel Economy: 51/45/41
Peter,
Where's your MAP sensor placed in comparison to the old tubing?
And how is the Boost curves you were looking at made? Did you Tee into a fitting on the intake manifold or... ?
I don't know too much about dyno's, but is this one of those ones that a 4th gear pull to redline takes like 5 seconds, or like 45 seconds?
The 400rpm later torque peak is what i feel is the fishy part.
2015 GSW DSG - 27kmi, Kerma engine tune
2011 JSW DSG - 160kmi, Malone DSG tune - Buyback soon
03 Jetta Wagon TDI 5MT - 175kmi, 2.5"F 2"R lift, 215/75r15 tires, self tuned
02 allroad TDI 6MT - 150kmi, current project, getting a BSM deleted BHW and euro TDI geared 01E quattro
Scott02 is offline   Reply With Quote
Old December 30th, 2008, 20:05   #407
MAP sensor is in the same place. And I'd say the pull takes about 10 seconds (that's a WAG, and I was waiting for something to break so it may have seemed longer than it was).
And what I learned today is that a dyno curve may not be a good indicator of what happens to the car on the street. What gear you're in, starting revs, whether or not you're on a hill or if the car's loaded or not--all these things affect when the car makes power. The peak numbers will be the same (or lower) but the position and shape of the curve can change.
What's also interesting to me now is I cannot make the car smoke now. Before I could 'catch' the turbo at low revs and get a puff of smoke if I got on the accelerator at, say, 1400 RPM in 3rd. Now it doesn't do that. And in the past if I trundled around town for a day or two and then got on the highway it would smoke initially. Not now.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old December 30th, 2008, 22:20   #408
MAXRPM
MAXRPM's Avatar
Fuel Economy: 57 mpg driving like a granny on HWY-5 from LA to SF
Same thing happen to me, recently I changed my IC piping from 2" to 2.5", now I see that my car has definitly less smoke, less egt's (big advantage) in the other hand I lost a little bit of the quickness from the get go I could feel it I know my car,,I really like quick sprints they are fun. but now I believe that if I continue to open the air flow with long duration cam and porting the head, my air swirl will suffer even more, making my car more letargic from a quick roll, peaking at a higher RPM,(no fun for me),
I am not an expert on this matter and please correct me if I am wrong, but I think If you would like to open the air passage in your car big time, I think the 17/22 is not the appropriate turbo to do that, you would need a bigger turbo with bigger blades to push all that air through the bigger tunnel.
I will have my car Dyno probably next month, so we'll see what kind of numbers I get after going from 2.0" to a bigger 2.5" IC piping , I will compare it with my old dyno, IBW I am also afriad about taking my car to the dyno, I would not like to pick up one of the rods flying across the shop.
MAXRPM is offline   Reply With Quote
Old January 1st, 2009, 20:20   #409
ArturCosta
Fuel Economy: (7.5L/100)(5.5L/100)(4.9L/100)
Here is my last one , allready posted on another topic but here is the right place:
Mods are on my sign.
Did not dyno futher into the RPMs because this was a test run... I was adjusting the remap but then I read the numbers and 180bhp was enought so boost was left at 1,65bars.
Engine is now with 342k kms , driving with this setup for 30k and runs fine torque from really low RPMs and power till 5000rpm
Regards,
Artur Costa
Audi A4 1.9TDi(110bhp) 1996
GT1852vb , PP764+T4 Injectors+hammer mod ,260 dbilas cam, 450nm kevlar clutch , 5speed TDI115 gearbox, 60mm inox exhaust pipe , fuel cooler,oil cooler , 5L FMIC
ArturCosta is offline   Reply With Quote
Old February 25th, 2009, 17:22   #410
adjat84th
adjat84th's Avatar
Default Stock 2.0 CR w/DSG
Finally got a full run with torque numbers after two failed attempts at different shops. Only problem with this one was I think the guy ran the car in 3rd because the speed seems pretty low compared to other '09s.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, DC stage 3 w/ SMF, Fluidampr
adjat84th is online now   Reply With Quote
Old February 26th, 2009, 17:23   #411
jaydogg007
jaydogg007's Avatar
TDI(s): 09 Jetta TDI
Thanks for posting. That's consistent with what I saw on my DSG...which is somewhere in this thread posted around 11/22/08 ish...
2k9 Reflex Silver Jetta w/DSG
(click for dyno on 11-22-08)
03 Blue Golf GLS 2-dr 5-sp
(RC3! also by BARTuning )
jaydogg007 is offline   Reply With Quote
Old February 26th, 2009, 18:03   #412
F1 tuning
TDI(s): Varios TDI
This Cars for some reason are not easy to dyno, and RPM are allways wrong... 6K on diesel ?.......
www.f1tuning.com
F1 tuning is offline   Reply With Quote
Old February 26th, 2009, 18:21   #413
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
That's speed, not RPM.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old February 26th, 2009, 21:08   #414
Farfromovin
Torque Addict
Farfromovin's Avatar
Fuel Economy: low: 35 high: 56 avg: 42.0
And some TDI's spin 6k... So many dyno shops have issues picking up a tach signal. Personally, I would refuse to pay if they couldn't produce an accurate tach signal, not something generated off of speed/gearing/math. A REAL signal. It wasn't too hard to stick some reflective tape on the side of my IP pulley on my ALH but I'm not sure how to do the PD...
[/old setup]212whp/354 ft-lbs14.862@96.677-Way faster than Chris [/new setup] At least 213whp, and way way faster than Chris.
Farfromovin is offline   Reply With Quote
Old March 4th, 2009, 18:25   #415
adjat84th
adjat84th's Avatar
Not sure why the graph is in MPH. They had an optical pickup...whether they used it or just used math to come up with the torque numbers is beyond me. They wouldn't let me see the car while being dynoed for "insurance purposes" but I could hear them running it. I do think they should have asked me about the RPM/MPH deal for the graph though.
Old March 28th, 2009, 18:37   #416
Lex4TDI4Life
Lex4TDI4Life's Avatar
Nothing new done to the car, but I went with my buddy up to a Mini dyno day and threw Josie on the rollers. Numbers are a little lower than my last dyno at NEDD VII, but in line with what I would expect:
I am thinking a lift pump will be next.
2001 Golf TDI 5 spd
RC2, Bosch T4-764 injectors, OMI, SBC Stg 2 Clutch, Koni FSDs, TT LCA Bushings, The Mystery Bar, Dieselgeek Panzer Plate, Elephant Hose, DG Race Pipe, Autometer Cobalt Boost Gauge, Boostvalve,Fumoto Valve, Mufflerectomy, Scangauge II
Lex4TDI4Life is offline   Reply With Quote
Old March 28th, 2009, 19:13   #417
Farfromovin
Torque Addict
That's a sexy curve right there! Lift pumps should be the next mod after clutch/nozzles/tune on ALH's!
Old March 29th, 2009, 12:50   #418
diffas
diffas's Avatar
Here is my lastest dyno with original nozzles. We can maybe do few more
horses out, but this is near to the limit for the 150hp AKN original.
diffas is offline   Reply With Quote
Old March 29th, 2009, 12:59   #419
fenwick458
fenwick458's Avatar
fenwick458 is offline   Reply With Quote
Old March 29th, 2009, 13:22   #420
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
Well done Fen!!
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Page generated in 0.16946 seconds with 10 queries
[Output: 130.31 Kb. compressed to 108.67 Kb. by saving 21.64 Kb. (16.61%)]
