JFettig
Log group 004 in VCDS full throttle in 3rd.
Will do. What am I looking for there? What readings are acceptable and if they are out of range, what is the normal culprit?Log group 004 in VCDS full throttle in 3rd.
I can't fit the 14's, my calipers just barely clear my BBS 15's. It took some investigation to find some affordable 15's to run in the winter and the Saturn wheels turned out perfect. Do you run studs on your tires? I'm debating whether I should stud them or not. I ran on the 225/50/15's last winter and the car was fairly useless in the snow.Nice choice on the tires, I have been running them for a few years and am very pleased with them. They wear like iron, have great traction, and aren't too loud. They are very similar to traction to the Blizzak WS-60's I used to run but they're cheaper and last a lot longer. I run the 185/70-14's, which is a little taller and narrower than stock.
I bought the full harness from someone, but thanks anyway. I just used flat black upholstery dye from the auto parts store, worked well.Hey fletcher I sold ya those leathers. I have the connectors and about a foot on each harness end. Want me to mail them to ya? Also what did you use to dye the carpet?
